Looking for a Air Conditioning Wiring Schematic For A 2004 Dodge
A/C on passenger side does not blow cold air... 2004 dodge ram 2500 4x4 diesel
  • 11,896 Answers
There is a flap that directs the air flow. The flap is controlled by a vacuum operated actuator inside the venting.
Posted on Jul 02, 2009
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
2010 dodge journey blows cold air on passenger side
Help with heating issues, blend actuator - Interior - Dodge ...
www.dodgejourneyforum.com/.../5304-help-with-heating-issues-blend-a...
Jan 13, 2014 - My 2009 Journey R/T is only blowing hot air out the driver side vents, while the other vents (passenger and rear) are blowing cold air ... Thanks Frogbox....keep in mind that the info is for the 2009 model and I guess it also applies to2010's. 2009 journy sxt heat/cool issue
Oct 16, 2014
Air Conditioning?
Dec 22, 2012
Rear heater A/C
Dec 22, 2012
More results from www.dodgejourneyforum.com
In a 2010 dodge journey why heat comes out just one side
Jan 10, 2016 | 2010 Dodge Journey SXT
2004 dodge 1500 cabin air filter
the cabin air filter is located on the passenger side of the cowl. after opening the hood, remove the windshield wipers and the black covering ( 2 small T-30 screws, and a few body grommets). after you remove the cowl there will be a grey accordion looking filter in the cowl, remove that and replace with the new filter.
Apr 18, 2011 | 2004 Dodge Ram 1500
2004 Dodge Ram 3500 Turbo Cummins diesel, air conditioning is cold but there is very little air pressure even when turned on high, fan sounds like it is blowing like crazy but very little air movement...
Sounds like the "Blend Doors" are not completely closed (or opened). The Blend Doors open and close to direct the air from the blower motor to the vent selection you have made on the control panel (defrost on windshield, floor, front, etc) You may need to try various selections to see if the blend doors actually open or close. If no changes, it could be a blend door actuator failing.
Aug 05, 2010 | Dodge Ram 3500 Cars & Trucks
Air conditioning blows cold on drivers side but warm air on passengers side.
dodge has dual blend door actuators on the air box. you have to pull the dash board assembly out to access the passenger side door actuator. it calls for 5.8 hours to do this job. you also have to evacuate and recharge the ac system.
Jul 19, 2010 | 2004 Dodge Ram 2500
2006 Dodge ram 3500 Turbo Cummins diesel, air conditioning is cold but there is very little air pressure even when turned on high, fan sounds like it is blowing like crazy but very little air movement...
flap broke. common problem. drop motor at bottom of dash, uses 3 bolts, reach up, grab flab twist and pull down. put motor back on. takes 5 min or less
Jul 07, 2010 | 2006 Dodge Ram 3500 Truck
2004 Dodge Intrepid air conditioning. Recharged
vacuum down to 30 inches for an hour recharge let me know what kind of readings you have
May 25, 2010 | 2004 Dodge Intrepid
2007 Ram Truck: where is low side of ac to recharge in 2007 dodge ...
The Low Pressure Side connector will be smaller than the High Pressure Side connector so the refill hose will fit properly only on the Low Pressure Side.
Read more: How to Recharge Air Conditioning with Freon in a Dodge Ram | eHow.com http://www.ehow.com/how_4484569_recharge-air-conditioning-freon-dodge.html#ixzz0uLXJnwvE
May 17, 2010 | 2007 Dodge Ram Truck
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
