Question about Dometic Rooftop RV Air Conditioner
I do not think it is as efficient as it was when purchased and I feel that sometimes it is not working when other times it is
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
How old is the unit? RV Air Conditioners usually do not deteriorate over time. What happens is they get dirty and when not cleaned on a regular basis, do not work well. If you get up on the roof and remove the shroud from the unit, you can inspect the condenser coils. They are the fins on the back of the AC.
Take a water hose and gently rinse the coils out with water. Do not use too high of pressure as this may damage the coils. Continue rinsing the coils until the water flowing through them is clear. Once you are done, replace the shroud and turn the AC back on.
Doing this procedure at least once a year will greatly increase the efficiency of your unit and prolong its lifespan.
Hope this helps,
Jeff
Posted on Jul 03, 2009
I have a Magic Chef freezer built older than 20 years. 15.2 cu. ft. pt. no. 101403-1
Hello Darrell;
My name is Peter. I am a retired field service technician.
Why do you think your Magic Chef is still working after 20 years? Your unit was manufactured with reliable cast steel components.
Do you want to purchase a new unit with more efficiency with components manufactured with plastic and cast ceramic. If you do decide to purchase a more efficient unit, do not discard your well build Magic Chef. When the new unit fails after 5 years, you will always have the older well built unit.
Nov 13, 2014 | Magic Chef Freezers
Tip
Radiant Heating - Why do You Feel Warm? The Best Most Efficient Heating System
What makes you feel warm on a sunny day in the summer? Radiant heating or radiant energy is usually recognized as the oldest form of heating. It provides the best comfort and is the basis for all types of heating systems. Radiant heating is "radiant energy" being emitted from any heat source. Radiant heating is the effect you feel when you can feel the warmth of the sun or a hot stove top element from across the room.
Radiant heat is widely known as the most comfortable and efficient heating method you can find. Some of the advantages of radiant heating are: it is usually more efficient than baseboard heating and almost always more efficient than forced-air heating because no energy is lost through ducts and other transfers. This technology can be used for both heating indoor and outdoor areas. These heating systems work by supplying heat directly to the floor, to panels in the wall or to the ceiling of a house. Because the radiant heating will make you feel warmer when you are in a room, you can have the thermostat at a lower temperature and still feel warm.
The feeling of warmth is the absence of heat being pulled from your body. If the walls, floors, and ceilings around you are warm then they are not pulling heat from your body. Then you feel warm. Your body is not giving up heat to them.
Because of this radiant heating systems can provide massive energy savings of more than 10-30% in most residences, and sometimes up to 60% in shops, hangars and warehouses. Radiant heating provides even warmth with no cold spots within a room. That provides a comfortable environment that cannot be matched by any other type of heating system.
New radiant systems are currently designed to run cooler than they did in the past. The water supplied to the systems will generally range from 90 to 140 degrees. Remember radiant heat can travel in any direction and is unaffected by gravity. Radiant heating systems will allow you to be more comfortable at a lower thermostat setting. Radiant heat will warm the closest and coldest mass, which then radiate heat throughout the space evenly. Radiant heating will give you the most consistent room temperatures from floor to ceiling when you compare it to any other heating system.
on Dec 12, 2009 | Heating & Cooling
Bad catalytic converter on 2000 Monte Carlo SS
My son put his tester on it, gave him the code ??????? What code ? P0430 -P0420
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0420 - Catalyst System Efficiency Below Threshold Bank 1
Sorry but you don't have a chance of doing this . special tools ,cost you you as much as to take to a shop . buying cheap cat's won't work either .
Oct 25, 2017 | Cars & Trucks
My laptop will not switch on, i have ordered a new power lead and it worked for a month, there are no lights coming on it just seems dead it was purchased july 2009 for christmas 2009 and first stopped...
Its a common issue for DELL systems. I recommend you request a MOTHERBOARD/AC /POWER CORD replacement .They can send a technician for you or send it to a depot repair.
Jan 20, 2011 | Dell Inspiron 1545 Notebook
Blows out cold air at times
In their effort to try to boost the efficiency of the heating units the fan sometimes runs even when the air will feel really cool...
The fan may start up before the heat exchanger is warm and may run after the heat exchanger has cooled off...
Probably nothing wrong... just the way it is...
heatman101
Nov 16, 2010 | Goodman Heating & Cooling
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Format Error Sony DCR-DVD108 C:1302
Hi Lisa,
What you have there is a bad disk. Sometimes that happens. Disks are made in mass and sometimes the company can make entire batches that are "bad". I recommend that you buy a known brand like memorex, although sometimes, they can mess up too. Just try another disk. Thanks for coming to FixYa, and feel free to rate my solution. Thanks again.
Rob
Feb 06, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Instructions required
I have a GE double oven. JKP44G with touch pad controls
Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
Could the connections in the control panel be dirty and not making connection at times?
Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
Nov 14, 2008 | Ovens
Fact or fiction. Are Rockford P10002 amps overrated
The efficiency of an amplifier has nothing to do with the RMS rating of the amplifier. It is true that no amplifiers are 100% efficient. The efficiency of the amplifier is calculated by how much power output it has compared to how much power it actually uses to create that output power. The RMS rating is just a measurement of the output power with no consideration of the amount of power that is needed to create that output power. Most of the high-end amplifiers are properly rated. If you see power ratings that refer to peak power, it is a little misleading. The true power of an amplifier is the RMS rating. It stands for "root means squared" but is the effective power that you hear, often referred to as the true power. It is calculated by taking the peak power and multiplying it by .707, which is always less than the peak power. When the rating of an amplifier is calculated they use a sine wave at a single frequency and it has a positive peak and a negative peak. If the power is calculated using both peaks it is called the "peak to peak" power rating. When it is calculated using only one peak it is called the "peak" power rating.
The big "con" in all of this happens when manufacturers use the "peak" power ratings instead of the "RMS" power ratings because it makes people think that the amplifier has more power when it really doesn't. Most people have no idea there is a difference in the "peak" power or the "RMS" power. It is a deceptive way of making people think that they are getting a more powerful amplifier. But none of this is related to the efficiency of the amplifier. It is theoretically impossible to make anything electronic that is 100% efficient. It always takes more power on the input than it does for the output power of anything.
I hope this answered your question, if you have any other questions feel free to ask them just by posting a response on this thread, and remember, you get what you pay for. The best amplifiers cost more for one reason, they are better. I am a big fan of Phoenix Gold amplifiers.
Dave
Sep 24, 2008 | Rockford Fosgate P10002 Car Audio...
5200 modem is very slow sometimes won't connect at all - can you help?
You probably need to reinstall the driver.
Here is a link for you. If you do not find what you need here, please feel free to get back to me for continued research.
http://www.dslreports.com/faq/eff/4_5200#8480
Thank You for using Fix Ya! Please take time to rate this solution.
Aug 23, 2008 | Efficient Networks SpeedStream 5200 Modem
Dometic Rooftop RV Air Conditioner Logo
63 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
