Question about Kenmore Washing Machines
Tub sometimes will not spin to wring out clothes.
When the washing machine exits the rinse cycle, the tub portion will not spin, it does not 'click' into place-- leaving the clothes saturated with water. However, if I lift the lid and spin the tub into a fixed position, it spins fine.
  • 999 Answers
Sounds like the machine is not pausing between cycles to allow the transmission to lock into spin.
Eric
Posted on Jul 02, 2009
My Whirlpool Duet is not spinning fast enough to rinse the soap out of clothes or get them rinsed enough to put in dryer, still dripping wet
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The final rinse isn't rinsing thoroughly. I have
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Aug 30, 2009 | Kenmore Washing Machines
Kenmore Elite Quiet Pak 4 less than three or four years old. Went through a "white cycle" but wouldn't finish the last spin. Had to hand wring out clothes. There is still water in the machine.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Aug 19, 2009 | Kenmore Elite 45986 Front Load Washer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
After final rinse water left in washing machine
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jun 13, 2009 | Kenmore 98702 Stacked Washer/Dryer
Does not spin after water is pumped out after the wash and rinse cycles
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 02, 2009 | Washing Machines
Doesn't spin to damp and fabric softener doesn't release.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Apr 10, 2009 | Kenmore Washing Machines
WMA34 - Issue with draining
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 23, 2009 | Washing Machines
Clicking in whirlpool duet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
186 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
