Question about Garmin nuvi 260W GPS Receiver
Need to do a factory reset for my Garmin 260W
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 17, 2010
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
I can't reset garmin nuvi 260w
Why do you need to reset it? What are you trying to fix?
Aug 22, 2013 | Garmin nuvi 260W Car GPS Receiver
My 260w has a screen lock and it has no reset button! what's the fix?
To reset the Garmin satnav you power on while holding the bottom right corner of the screen until it asks if you want to reset it.
Jun 12, 2011 | Garmin nuvi 260W GPS Receiver
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
Garmin 260W free updated map
Hello.
You can go to mygarmin.com or garmin.com . You have to register. It is for FREE. Then,you can update your GPS. You can also download maps by just following the screen instructions.
You can also find all the software/drivers you need there.
Hope it helps.
Apr 07, 2010 | Garmin nuvi 260W GPS Receiver
Have Garmin Nvui 260w that has lost it maps. earlier purchased mapdates and hasn'b been the same. shows Garmin and computer on sceen.
GO INTO SETTINGS
THEN MAPS
THEN MAP INFO ,
MAKE SURE THE "TICK" IS IN THE BOX OF THE MAPS YOU WANT TO USE
IF THAT FAIL'S THE THE DOWNLOAD DID NOT TAKE, IF SHOWING COMPUTOR ON SCREEN STILL, THEN RESET, EITHER THE RESET BUTTON ON THE BASE, (PUSH) OR HOLD/PRESS BOTTOM RIGHT CORNER OF SCREEN WHEN POWERING ON AND WAIT, THEN RELEASE PRESSURE TO HARD RESET
Dec 29, 2009 | Garmin nuvi 260W GPS Receiver
When I turn on the Garmin 260w, it takes me to the screen that says, "No detailed maps found that support routing. The nuvi cannot be used without them." It will not let me proceed. I have had no...
You may need to reset your unit. You can contact Garmin customer support at 800-800-1020. They will talk you through the reset steps for free!!! Good luck! PS - wait time on hold can be long but worth the free fix!!!
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
How to change Chinese character to English/Romanise on nuvi 260W
1. Press the wrench (tools) button.
2. Press the Setting (gear) button (upper left).
3. Press the down arrow until once.
4. Press the 2nd row function (language).
5. Press the middle button of 3.
6. Press the up button until you see the function American English and select it.
7. Hit OK.
You should be back to English now.
- Jim
SHARCNET-USA
May 03, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w does nor start at all, itis dead
there will be a reset button, take a pen and push the reset button providing that the sat nav is charged it should reboot.
Apr 05, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
1,577 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
