Unfortunately there isn't a way to say exactly what board is causing the issue, plasma sets are a lot harder to repair as there are at least double the amount of boards in them and several boards cause similar issues.
If you have replaced all the boards, including its power and main board, some critical adjustments should be done. The TV wont switch ON, without these adjustments. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
you must resolder all the colder joint with a solder. that the first step. However if the problem remain, you must test some components such:capacitos+resistor+diode+transisit+I.C for faulty and replace. test any fuse or c.breaker in the board. God bless you
Main digital board should be troubleshooted. If
you are not familiar with electronics, do not attempt to repair.Whether you sufferfatal electrical shock!
Instead, contact any experienced service technician, or the nearest service
center
