Question about Canon Office Equipment & Supplies
Paper jam will not clear
Canon Imagerunner 1630. Installed new drum unit and assembly. LCD screen still says rec paper jam. When I slide the platen and open the cartridge cover door, the machine does not register that door is open.
Is there a way to manually reset or get into service mode?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
You have a stuck or broken sensor
Posted on Jul 05, 2009
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I'm getting a message stating Rec. paper jam slide platen left. Can you please help me someone donated this copy machine to the church however I need to repair it. Thank You!
after yoy slide, open up the cover and then you will see the cartridge (black color) then you pull out the cartridge (there is a holder steel).
and you will see the paper jammed.
take it all, do not be left one bit.
and then replace all like a before.
May 29, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
I am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Mar 15, 2009 | Canon imageRUNNER 1210 Copier
Paper jam
make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Nov 11, 2008 | Canon Office Equipment & Supplies
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
222 people viewed this question
old marine
old marine
