Mitsubishi wd-52327 Will turn on for 5 mins then shut off
I just replaced the bulb thinking it was possibly the bulb with a brand new one... same thing happens the TV will turn on for 5 mins, Shut off and will not turn on for another 30-40 Mins......?
I am not really sure as to what to single out first or even to trouble shoot it wether it is the Light engine ballaste color wheel?
Any help would be great!
thanks
Dan
  • 100 Answers
Check capacitors on power board(electrolitic).voltages:5v,6v,8v,9v,12v.
Posted on Jul 03, 2009
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-73638 no picture and shuts off randomly
I would think that the item to check would be the power supply. You will have to take the TV apart, get the board part number and see if you can find a replacement for it. I would recommend putting a meter to it to verify it is the board that is bad.
Mar 12, 2014 | Televison & Video
Do i need to buy the bulb housing for a WD-52327 or just the bulb?
You can do either, it's your choice. A lamp only replacement will save you a bit of money, but the installation will take just a little while longer. You will need to remove the old lamp from the housing and transfer the lamp connector to the new lamp. You should use either gloves for this procedure or at a minimum use a paper towel to handle the lamp. WASH YOUR HANDS BEFORE AND AFTER... these lamps contain Mercury.
Mar 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
WD-52327 Red Light Problem
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Jun 05, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Aug 06, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
