Tv not switching on. even if it's on picture is not coming only sound.
  • 11,896 Answers
It is likely that you have a bad capacitor on teh DM board that will need to be replaced
Posted on Jul 02, 2009
I just bought a Hitachi rear projection tv off craigslist. Tv worked fine, I gently transported to get it home, plugged it in and for nothing. The red light comes on and it sounds like its trying to come...
no matter how careful you going to be moving it something is going to come lose. may even be a bad soldering joint and it come away completely. you will need to check the power board very carefully looking for somthing that dont look right. also this can happen in transit the outer case for the bulb housing may have moved away from the switch that would make the tv not turn on at all as it needs to be pushed in. take the cover of it and then put back on locating the switch you will see the switch when the cover for the buld is removed..
Oct 22, 2013 | Hitachi Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
When switching T.V on, the sound works but without a picture
I personally dont think its the power supply, you're getting power, and I could be wrong, but it sounds like bulbs or modules that enable your "picture" is faulty. Check the owners manual for troubleshooting tips too, companies are making flat screens so fast nowadays that they install faulty parts and don't even realize it.
Nov 13, 2008 | Televison & Video
50" Plasma HDTV
Hello ndulgebeauty,
This sounds like a power supply problem. I would advise that you get a qualified TV technician to troubleshoot this problem. The reason being is that the TV does not come on at all. The problem might be the main power board (AC to DC) or the secondary power board (Switching Power Supply and distribution board). Have these checked first.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Televison & Video
Red power light comes on and no picture
Sometimes after a move,a bad solder connection causes a
part failure,maybe just a fuse device....have it checked by a
qualified technician.............T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
