Question about Garden
KARCHER MODEL KB5050 PRESSURE WASHER BUZZES BUT WILL NOT WORK
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
  • 313 Answers
SOURCE: Water is pouring out of
seal or oring problem.see www.pressureparts.com for parts etc
Posted on Jul 08, 2008
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Dec 04, 2009 | Karcher K2.26 Electric Power Washer
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
I have a Craftsman pressure washer. I have no how to book.
If you contact karcher using the link below, they will e-mail you a manuel in pdf format.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
