Question about Cameras
The rear element has a scratch on it about the size of the end of a ball point pen, can the rear element from another 80mm lens be used as a replacement?
  • 9 Answers
The sort anwser is YES. But ... it has to be from an equal model.
Posted on Jul 03, 2009
Best way to fill in a deep scratch on car door caused by what I assume was a key...?
At Canadian tire they sell paint that comes in a pen type canister. has a ball point end and a brush. use the ball point end and just trace the scrtch with the paint pen. (exact match paint) this will hide the scratch well, but for best results. do a few coats. letting it dry between each time. which doesn't take long. and it will built the paint up flush to the original paint. when its dry. wash and wax over the surface.
Feb 16, 2013 | Cars & Trucks
I have night owl optics mmoncular that needs the front lens replaced. where do i go to order the part?
That lens is a F1.7 with 80mm input lens. Take threaded end an measure it diameter and thread sizes. You could up dat this lens to 90 or 100mm. Ask Night Owl Optics in El Paso, TX. And listen to what they have to say. You can check with Optics companies with demenision of the front lens and they probably matich it up. stewbison
May 04, 2011 | Night Owl Optics Cyclops Pro NOCP5...
Mount broke won't attach to camera, where can I get replacement part?
dolphindaddy,
I have the same problem. (I call it a broken rear lens plate.)
I purchased the Nikon for this same size. However, I like the Sigma lens so much more. I can hardly wait to get it back onto my camera.
BobofOrd
Jan 09, 2011 | Sigma 28-80mm Mini Zoom Macro Lens
I have several old,some very old cameras which have due to obviously wrong storage developed fungus inside the lenses. I am a retired engineer, but do not know how to remove the lens front without doing...
This is a tricky job- you have to be able to reassemble not just the lens components but the aperture diaphragm and focusing components. There are lots of little springs that jump out and sometimes tiny loose ball bearings.
But if you feel confident- most front lens elements are held in by a retaining ring that can be unscrewed. On older lenses this is obvious, with a couple of slots in the retaining ring, one one each side. You need some kind of tool to engage these slots without slipping and scratching the glass. I have actually used the points of the blades on a pair of scissors, but this is obviously not to be recommended.
On later lenses, there may appear to be no slots. Usually this means that the actual retaining ring is hidden behind a dummy. If that is the case, and there is no way to be sure but to try, you can unscrew the dummy ring by using friction, with a disk of rubber cut from an old innertube pressed against it, or maybe a rubber glove. This ring does not have to be screwed up very tight, as it is only cosmetic. Sometimes this ring is the outer surface of the front end of the lens housing, and sometimes it is an insert.
Sometimes it is easier to get at the inner surface of the front element by disassembling the lens from the rear, which is usually a matter of removing a lot of tiny screws.
However you get in, you are likely to find that removing the the mold does not clean the lens completely. It will have etched faint lines into the lens coating, and you will also introduce a certain amount of dust, which I have never managed to eliminate entirely.
Oct 20, 2010 | Canon Cameras
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Tokina AF 28-80mm f/2.8 AT-X Aspheric Pro...
Currently I have a Nikon F65 non-digital camera with 28-80mm lense. I am planning to buy a Nikon D5000 DSLR. My Question: If i buy a Body on D5000 and will be able to use my f65 lenses? Will there will any...
If anything, you will gain image quality because the sensor on the D5000 is smaller than a frame of 35mm film. Thus you will only be using the central portion of the lens. On the D5000, the 28-80mm lens will act as a 42-120mm would on the F65.
However, you will lose autofocus capability. The D5000 does not have a focus motor in the body, relying on the lens having the motor, and neither version of the 28-80mm lens has a focus motor. The lowest-end Nikon dSLR with a focus motor is the D90.
Feb 07, 2010 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Scratched front lens element
Well, you cannot buy the front element by itself. The whole front optic set comes as a unit. You can call Canon USA, ask for parts,
1-800-828-4040
The part number you are inquiring on is: CY1-2800
Have you taking any pictures with the lens? usually it takes quite a bit of damage to effect images. The rear optics are the more sensitive glass on all lenses
Oct 03, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Spin ball. Cursor barely moves on screen.
Have ya tried removing the ball and cleaning the infrared screen under the ball with a cue tip? Also get all the finger grease and gunk out of that area too. You can remove the ball with a pencil or pen, use the dull end of the pen or the eraser end of the pencil, so you don't divot/dent the ball.
Aug 17, 2009 | Logitech Trackman Wheel 904353-0403...
How to
simply replace the scratched screen
Apr 03, 2008 | Nintendo DS Lite Console
Diagram of parts in sigma 28-80mm zoom lens
Hi The front lens just screws in and no locking ring
Nov 18, 2007 | Sigma 28-80mm Mini Zoom Macro Lens
Cameras Logo
214 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
