Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
24 h intek broken rod
I have a 24 horse B&S Intek motor in my Craftsman lawn tractor. I changed the oil at the begining of the season. The third time I cut my 2 acre yard it started making a horrible noise. I shut the engine down immediately and pushed back to my garage. I checked the oil and it was still on the full line. I had Sears come out to look at it. That took over two weeks to get them out. The mechanic turned the engine over and said, " Yeh, it has a broken rod. It is out of warranty so it will cost $1800 to replace the motor." The warranty ran out 2 months ago. Sears will not help me with the issue. Sounds to me like this particular motor is known for this problem as well as carb and ring problems. Does anyone have any suggestions? Will B&S help at all?
P.S. Don't by from Sears!
  • 4 Answers
It is very easy to get and install a new engine. I would suggest Oklahoma small engines or Jack's small engines or Kansas City small engines. Oklahoma doesn't have shipping charges. The only thing you need to know is the shaft size and length. Craftsman mowers usually use a 3 1/4 " long by 1 inch shaft. The bolt pattern is the same where it bolts to the lawnmower etc. To find out what size shaft you have without taking the drove pulley and pto clutch off, you can take your exaact model and series numbers, call briggs to get the measurements; then call the online suppliers above and order a 44P777 or 44Q777 to replace it. P is last year and is on closeout. I got one for 700 bucks at my door. You will only need socket wrenches to get the 7/16 by 4" bolt from the bottom of the shaft, and four bolts from the housing then throw her away(recycle). I spent over half as much money on the old design and rebuilt my last engine perfectly and onlly got 30 to50 hours from it. when you hook up the throttle, you need to get someone with a tach to make sure it does not go over 3600 rpm. Do mark the old position of where the cable is clamped with a sharpie to get close. On my mower, the wiring matched exactly; which is likely in your case and all I had to do is cut my fuel line short to go to the left of the motor instead of the right side.
Oh, by the way the model # I gave you would be a 26 horsepower replacement and it will do fine. I don't think there are as many deals out there on the 22. They are the same size. the first two numbers in the model # indicate the size of the bore. The 22 has one eight of an inch less bore than the 25 hp. I belive the 22 model # starts with a 40. third # doesn't matter. 777 means vertical engine, standard bearings, pressurized lubrication, electric starter, alternator which is standard on craftsman mowers. Note: the engine I got did not have the ring that snaps into place around the recoil screen and should be ordered. I went ahead and ordered a tach at the same time. There is an exact sequence for setting the low rpm throttle setting, low rpm governer setting, then the high rpm governer setting by bending some "tangs" with an allen wrench that you saw a groove across the end instead of buying the tool.
Your'e ready to go with a new engine that has a two year warranty, a better system for filtering the air intake, and a better crank lubricating port arrangement than the original. Now, start using synthetic oil.
Posted on Jul 08, 2009
  • 4 Answers
Pull off both valve covers and look for a bent pushrod.
Posted on Jul 06, 2009
  • 376 Answers
Briggs might help, but doubtful since it's out of warranty. But, depending on why the rod broke (if it did break...Sears doesn't have the most knowledgeable mechanics) and being so soon after warranty, it's worth a try. As for $1800 to replace the engine...ridiculus. Perhaps if you bought it from Briggs at list price you'd have to pay that much. There's plenty of places on the internet to buy them cheaper. If nothing else, I could have one drop shipped to you for around $800. They are good engines. Usually it's owner neglect that shortens an engine's life
Posted on Jul 02, 2009
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 20 hp B&S Craftsman Intek egine. It is burning oil (smoking). his is only the second season for this mower and I mow only a small lawn takes about 1 hr. I changed the oil religiously. The...
i would say it is the head gasket , there is only a little space between the valve train and the piston, and this is where the gasket lets go, when the piston goes down on intake or power it sucks the oil past the gasket then out the exaust valve
Aug 15, 2011 | Parks Optical 13.5hp Briggs And Stratton...
Where to buy a new oil filter and fuel filter?
You can buy a new oil filter and fuel filter at the briggs & stratton website here are the exact links
oil filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={803C6266-A7A3-4F83-A56E-8148DE31F0F6}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
fuel filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={7135A082-B7B4-4F72-B4AF-29FBEBB661C5}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
Regards obliqueridge
Nov 19, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman Tractor (B&S 20 HP Intek) starter motor spins, but the gear does not move up and engage the fly wheel. How is it supposed to work? Can I fix it?
All it should need is a kit that gives you the top half of the starter. I just did one on my 12hp craftsman. The kit was $23.00 and even came with the directions. very easy. Hope this helps
Apr 21, 2010 | Parks Optical 13.5hp Briggs And Stratton...
24 hp intek has no power when under a load mainly when blades are engaged blows smoke like crazy.i pretty sure rings are shot,but the no powers got me stumped. valves are adjusted properly. i thought it...
I have good news for you,well sort of,the rings are probably ok.The intek engine is noted for blown head gaskets.They leak between the cylinder and the push rod chamber.A way to check is to start the engine for a minute,turn it off and pull the dipstick out,if you see vapors coming out of the oil fill tube it has a leaking head gasket.To check to see which cylinder is leaking, check the plugs,there will be a oil residue on one or even a brown crusty build up on the side that has the leaking head gasket.If you remove the head you will probably see a small piece of the gasket is missing on one side of it.
Aug 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,101 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
