Question about GE Profile PDS20SFSLSS Stainless Steel Bottom Freezer Refrigerator
GE PROFILE BOTTOM FREEZER PDS20SBSALSS Digital temperature reading for freezer rising. outside of compartment very warm. Fridge temperature now 44, Freezer at 12. Settings have not been changed. quick fix? or need to call in a tech (warranty just expired...perfect).
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerGE PROFILE BOTTOM FREEZER - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Fluctuation of temperature GE Profile
g.e has mother boards or computer board in them located on the back outside wall,your board is on the top left,part number wr55x10942,everything on your machine runs through that board,also look at the evaporator coil where the thermostat is,there's a sensor on the top of the coil,it looks like a white bullet,if there's a black ring around it where the wires connect to it you also have to change that too.wr55x10025.go here and look at picture,if your board doesn't have all the relays like on this board then you don't have the updated board
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075the new board has all 7 relays and is the newest board.hope this helps and good luck with it.
Sep 12, 2012 | GE Refrigerators
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Temperature is reads 73 on freezer and 34 on refrigerator But... inside all are warm Help
It may be vice versa.
You need to check and make sure that the freezer section is 34 degree. The refrigerator compartment depends on the freezer in order to maintain a temperature suitable for food storage. If it is the case, you defrost heater and thermostat may be defective.
Dec 10, 2010 | GE Profile Stainless Bottom-Freezer...
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
GE Profile PDS20SFSLSS Stainless Steel Bottom Freezer Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
