Question about Hayward Navigator Pool Cleaner
My navigator seems to stay primarily in the deep end. doesn't seem to be able to get to the shallow end.
    Problem Solver:
  • 7 Answers
Could be several things. If no blockage at inlet hole, feet are in good condition, springs in place and moving freely, etc., I would suggest too little suction. Use the gauge that came with the unit to check for acceptable level. If you don't have that, it will just be trial and error to get it right. Unfortunately, you can't set these once and expect them to remain functional. Suction is always changing depending on filter pressure (blockage), skimmer baskets full, etc..
Posted on Jul 05, 2009
I have a pool vac ultra in a variable depth pool. There seems to be too much buoyancy in the unit, it keeps on going up on one wing as it travels up the slope between deep end and shallow end.
Sometimes you need to burp out any trapped air under the vacuum as you place it in the water. Trapped air bubble can cause that. I have had to fasten a light diving weight to mine once before I figured it out.
Dec 22, 2016 | Vacuums
Deep end only
adjust floating handle
Jun 03, 2013 | Aqua Vac Tiger Shark
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Doesn't clean shallow end
try aiming the return ports to direct the cleaner to the shallow end
Jul 31, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Polaris hangs in the deep end
Check to see if one of the drive belts is broken. You'll need to pull the wheels and separate the housing to inspect. Also make sure that the thrust jet is centered and pointing towards 12:00. This unit should back up after 3 minutes and reposition itself.
Apr 21, 2009 | Polaris 380 In Ground Pool Cleaner
Hayward Navigator Pool Cleaner Logo
1,346 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
