Question about Eclipse (XA1000) Car Audio Amplifier
Dont know how many watts it is
NEED TO NOW HOW MANY WATTS IS MY ECLIPSE AMP. ITS a 32430 premium series
    Problem Solver:
  • 16 Answers
Ahh..ran across this one not too long ago...4/3/2 channel amp. What you have is a 640watt @ 2 ohm PEAK, 480 RMS, 320watt 2 4 ohm RMS.
Posted on Jul 02, 2009
    Top Expert:
  • Eclipse Master
  • 79,847 Answers
85WX4
How much watts does a JL audio 10w0-8 have?
the 10w0-8 are 8 ohm speakers and rated rms is 125 watts, an amp running 300 watts is perfect and you need to wire it in series to pull a 4 ohm load from your amp. if amp is larger than 300 watts rms it will kill the w0's in a quick minute.
Mar 15, 2012 | Car Audio & Video
I got to 12 they are about 400 watts each what would be a good amp to put on it to lift the subs
Hello jeremymikjha,
Basically you want to match the subs in impedance and power.
With 4 ohm subs wired in parallel, the final load will be 2 ohms. Depending on how hard you want them to hit, a pair of 400 watt RMS subs will need an amp that delivers 600-1,000 watts into a 2 ohm load.
The enclosure you use will also make a big difference. A sealed enclosure will need more power. A ported enclosure will be louder with less power.
The Hifonics shown here would be a good choice for a sealed enclosure. It's rated for 1,100 watts RMS into a 2 ohm load.
http://www.sonicelectronix.com/item_17598_Hifonics+BXi+1610D.html
The Eclipse XA1200 outputs 600 watts RMS into a 2 ohm load. It would power the subs very well in a ported box.
Somewhat less expensive but good quality would be one of the Alpine MRP series. The MRP-M500 is only $179.99 at SonicElectronix. It delivers 500 watts. It's big brother is the MRP-M1000 with twice the power. Be sure your subs are securely mounted or this amp will literally "lift the subs".
Hope this helps.
Oct 19, 2009 | Rockford Fosgate Punch 301M Car Audio...
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
I have a 12 inch eclipse sub aluminum but i have no info on watts or ohms i only know its a single voicecoil
put a voltmeter on the terminals and set it for ohms and it will give you a reading somewhat close to the rated ohms of the sub-as far as watts go unless its built to the hilt just figure between 250 wrms and 500 watts rms
Jun 05, 2009 | Eclipse Car Audio & Video
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Looking for eclipse 32440 premier amplifier
is this a good power amp what are todays sinfo on it
Feb 10, 2008 | Car Audio & Video
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Baffled
AudioBahn A2401Q Car Audio Amplifier: 100 watts x 2 @ 4 ohms stereo 140 watts x 2 @ 2 ohms stereo 280 watts x 1 @ 4 ohms mono ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | AudioBahn A2401Q Car Audio Amplifier
Eclipse (XA1000) Car Audio Amplifier Logo
255 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
