Question about Garden
Need a schemitic showing the fuel ans oil lines. need to run new lines
  • dontbother10
    dontbother10 May 11, 2010
    Each model is different. There were probably 50 different models made by McCulloch.
  • 157 Answers
Go to the website that makes your saw
Posted on Sep 18, 2009
Does the 94 lincoln tc exec come with the pats system
if its been sat for years the fuel filter has probably deteriorated, and its now in the fuel lines. there is a number of parts that need changing before you start an engine that has not been run in a long time. fuel drained, fuel filter changed, oil and filter changed. fuel goes off after a year or 2. oil can turn to sludge in the sump. and block the oil pump. this can also affect the oil pressure sensor.
Apr 14, 2018 | Lincoln Cars & Trucks
The tractor will start, but runs ruff as if the choke is stuck. When the blades are engadged, it runs worse and can smell gas. Gas smell is in the oil as well.
May not be the carb at all. You have somehow managed to suck gas into the oil. Take the plug out and crank it a few times. It will likely throw excess gas and oil out of the cylinders. I had the same problem with a brand new (5 hrs.) DR Field and Brush Mower that was equipped with a "carbon recapture unit" - a ridiculous new EPA requirement. Rather than a simple vent on the gas cap, these geniuses have put a valve at the top of the gas tank with a hose running back into the carb. No problem until you fill the gas tank and try to mow uphill more than at 25 degree angle. Then, what happens is when the gas level in the tank makes contact with the valve, you wind up with an air filter full of gas and gas/oil in the cylinder. You'll need to replace and gap the plug, drain and replace the oil, install the CRU (if it has one) replace the air filter, and it should be ok. I'm going to bypass this CRU. The EPA, for all the good work they do, gags on a gnat but swallows a camel. Good luck. P.S. My DR is still in the shop.
Mar 23, 2016 | John Deere Riding Lawn Mower. D170 54 in....
I put on a new fuel line and air filters but now my heater will not draw fuel up?
"New fuel line" reads to me as though it is an oil burner. If it is, once the new line was installed, the oil filter canister needs to be bled of air so the oil pump can draw oil. There's not enough information to give much of an answer.....
Dec 25, 2014 | Heating & Cooling
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
I have a cub cadet #2135. Had it overhauled last winter--new blades, new battery, new pto switch and changed oil. Recently the mower runs for about half an hour and then quits--seems to be too hot--but i...
Maybe your fuel is getting too hot and causing it to be vapor locked. Check to see how far the fuel line and the fuel filter are from the engine on the approach to the carb. If you are able move the line away some. You may want to move the fuel filter closer to the carb. so that any vapor bubbles can come out in the upper part of the filter allowing for free flow of all the way to the carb.
If really helpful, please rate.
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Changing fuel filter and transmission fluid on a 1990 gran prix
just follow the fuel line and you will find the fuel filter ,but if its running ok then just check the fuel lines for deterioration and leave well alone ,the fuel pumps at the garage have filters in them so you shouldnt need to change the filter unless the metal casing is rusting,as for the transmission again if it works ok then do not disturb as its only hydraulic oil and it doesnt get dirty like engine oil but if your gearbox is showing signs of bad changes and you can see bits of worn brake band in it then change the vehicle as even if you change the oil it will pack up with or without a oil change.
Jul 15, 2010 | 1990 Pontiac Grand Prix
'79 Chevy van has been in storage for five years. How do I get it running again?
Start by cleaning the fuel tank (water from condensation accumulates in it), clean the fuel lines, clean and adjust the carburettor, drain the old oil, remove the sparkplugs,put some fine oil in the cylinders and crank the engine manually, put new oil,oil filter,sparkplugs,distributor cap and air filter, replace the water and start the engine. Check for leaks, run the engine for an hour followed by an oil engine cleaner.
May 22, 2010 | 1979 Chevrolet C/K 3500
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
I need a diagram showing fuel filter placement
try "autozone.com" or your local library for diagrams or step by step instructions
Mar 08, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
Hope you got this fixed. Sounds like you were having fuel flow problem.
Jan 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
