SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
SOURCE: Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
SOURCE: Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
SOURCE: Accurian 7-inch dual screen portable dvd player apd-3911
We had the same problem. Since ours was off warranty, I took the back off (several small screws) and lubricated with some fine oil the track (two silver rods about three inches long) upon which the lens slides back and forth. It can be tricky to get it apart and back together again. I also manually slid the lens carrier so that it was in the middle, partway away from the center spindle. Now ours works fine. I think the problem was that the lens carrier doesn't slide very well or gets stuck on the track rods.
