Question about MTX Car Audio & Video
I turned my system up all the way for about 2 mins and the mtx 801D amp stop working, it lights up and the fuse is not blown but it won't power the subs.
    Problem Solver:
  • 16 Answers
Had a friend with same problem...paid me to look at it and well...amp was just overheated or short/loose ground.
Posted on Jul 02, 2009
No sound on my amp
Do you have the remote power hooked up on the amp? Have you checked the fuses? or maybe the audio wires are bad.
Aug 13, 2012 | MTX Thunder 801D Car Audio Amplifier
Wont power up
Providing you also ran a ground direct from battery, you need a trigger wire from stereo i usually run off power antenna wire.Some stereos have a seperate amp or trigger wire already coming out you just need to run it to amp.
Jun 06, 2010 | MTX Thunder Elite 801D Car Amp
Mtx 801d amp turns on but no bass just high pitch sound sub is fine
if theres a switch on ur amp that says LPF Full or HPF put it on LPF for low pass frequencies
Mar 16, 2010 | MTX Thunder 801D Car Audio Amplifier
Amplfier mtx rfl404 goes into safe mode when playing at load volume after 10 mins
you might need to turn the amp down and get some better wires to carry the load. when at lot of juice is being tranfered you need good wires to hold it
Mar 14, 2010 | MTX Thunder 801D Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Mtx 801d
ASSUMING that the amp is OK with a 2ohm load then you "set it up" by the configuration of the speakers you use. Two 4 ohm speakers if parallel will give you a 2 ohm load. However, if you are bridging the ouputs then a single 4 ohm speaker bridged between the two outputs will put a 2 ohm load on each channel. Be very careful if you are bridging the outputs that you know what you are doing. On average, when bridged wrong (too much load) the amp will last about one month before it fries. Get some help if you are bridging. Be sure not sorry.
Jan 14, 2007 | MTX Thunder 801D Car Audio Amplifier
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
579 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
