Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 24 kohler engine
The battery wont charge, anybody knows where the alternator is?
  • 513 Answers
There is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Posted on Jul 04, 2009
Kohler cv15s
Your battery may bad. Unhook it,check voltage, charge it 24 hours. Check voltage, should about 12 volts. Let set 24 hours, check voltage , if not 12 volts, no good.
Aug 20, 2013 | Craftsman Garden
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Wiring harness is missing
If all you want to do is see if it runs, forget the wiring. There may - or may not - be a connection on the bottom of the carburettor. If thers is, connect it to the battery +.
Use lump leads - ground the battery '-', and connect battery + to the starter. Engine will crank. Operate choke/throttle controls as necessary.
One of the wires in question will be the engine cut-off. The others will be DC out (battery charge and clutch), DC (or AC) out for lights etc, and alternator ground.
Use a test meter to determine what's on each wire. The one with no (measurable) output will be the cut otff. Ground it to stop the engine (or pull off the plug lead).
May 07, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Location of battery charge problems
The alternator, for producing 120/240vac, is located at the other end of the engine. The alternator for charging the battery is part of the AC alternator.
Charging circuit breaker? Don't know that one, I thought they were fused near where the battery was installed.
Apr 13, 2010 | Kohler 12 kW Emergency Power System -...
Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
222 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
