Question about Poulan Garden
Need manual for a Poulan Pro 35cc 16 inch Chain Saw that I can download online... Purchased, used, from a friend without a manual. A manual in PDF format would be awesome and much appreciated... I have never used a chain saw before...!
    President:
  • 2,220 Answers
Your manual can be purchased here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The IPL can be downloaded free.
I haven't found any source for the operator's manual. We cannot help you further with this question.
Posted on Sep 12, 2009
How many drive links does a McCulloch MCC1635A 16-Inch 35cc 2-Cycle Gas-Powered Chain Saw bar have ?
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Sep 02, 2014 | McCulloch MCC1635A 16-Inch 35cc 2-Cycle...
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Can I put a 18" bar on my Poulan 35 CC, If not why.
yes you can put an 18 inch bar on this saw. you could even go with a 20 or 24 inch bar as long as it will fit the saw. I wouldn't go much bigger though because it really doesn't have enough power to handle a much bigger bar. And, getting into the dirt makes the saw chain really dull really quickly. Dig around those roots if you don't want to be stuck sharpening your chain every 10 seconds. Take it to your local saw shop and they can fix you right up! Hope this helps...
Jun 26, 2013 | Poulan Pro PP3516AVX 16" 35CC Gas Chain...
How can I get a instruction manual for my Poulan Pro 35cc chain saw. I have miss placed mine.
Check the link below for your model. If not available as a download, the contact info is on the left side of the page. Poulan is now owned by Husqvarna, BTW.
http://www.poulan.com/node7925.aspx
Aug 27, 2011 | Poulan Garden
I can start my Poulan 2000 16" chain saw but it
If the saw is brand new, take it into a service dealer for a carb adjustment (covered under the warranty). This sounds like it is your issue and unfortunately, you cannot correct it yourself because it requires a special tool.
As for you manual, it is located at the link below http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Jun 25, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Remove chain guard
The OM for your saw is is the best guide. You can download a replacement here (disengage the chain brake first - pull handle aft):
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
A broad adjustment procedure can be found here. Completely remove the bar cover, slide the bar against the drive sprocket, remove the chain from the bar.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Removal and installation of chain sprocket for poulan pro 295 chain saw.
Download and open the link below:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
See page 16.
This may also be helpful (bottom), it is possible to mount a chain backward.
Lou
Mar 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
860 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
