Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 error code
I have any error code on my xerox phaser 8200. I can not do anything, I have tried shutting it off but it contiuned to give me the same error code Fault # 15.004.45:123758
Can anyone help me?
  • 39 Answers
This error is probably that both or more likely one of the drum heater elements has blown (often referred to on here as bulbs) The error code refers to the drum not reaching temperature in time
Posted on Sep 17, 2009
I have an error code 13.004.43:275669
Posted on Aug 20, 2009
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Posted on Aug 11, 2009
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error code 07,005.30553
Hi rita619:
Your process gear motor is giving you a problem. You have to call Xerox and have them fix it for you. WWW.Xerox.com
Apr 01, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200 will not start up
Are you getting any fault codes on the screes? A fairly long number..
Jul 29, 2008 | Xerox Phaser 8200 Laser Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
336 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
