Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I have replace my water and the waer has stopped
I have replace my water filter and the waer has stopped coing out
    Problem Solver:
  • 7 Answers
Remove the new filter and re-instal. If this doesn't solve problem I would put the old filter back in and try. If you now have water remove the old and try the new one again. Don't forget to push firmly as it may have not seated fully.
Posted on Jul 23, 2009
AFTER I CHANGED WATER FILTER IN WHIRLPOOL FRIDGERATER THE WATER COMES OUT HOT
Are you sure that your water line is hooked to cold water. It sounds like you are hooked up to hot water and not cold.
Jul 30, 2014 | Whirlpool Refrigerators
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Water flow ok to side valve. no waer flow to top of 1042-l unit. valve extremely hot. is there an expert service maitenance available in montreal
Replacing this solinoid valve is not hard to do. This is something the homeowner can accomplished with small hand tools. Turn power off at the furnace and the inlet water off at the saddle valve.Remove the water line at the valve and the connector exiting the valve. Remove the two screws and the valve is off the unit. Armed with the make and model number of the unit goggle the manufacture with the model number and order your replacement valve on-line. Install the new valve opposite of which the old valve was removed or per manufactures instructions that may come with the new valve you orderd.
Jan 23, 2011 | General Filters 1042-LH Humidifier
No ice or water, changed filter , still no ice or water
changing filter is not the answere .. but do ck the control panel as ice & waer do not fail at same time . loos connections to the board ore very common .. mm
Aug 09, 2010 | Refrigerators
Problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Apr 30, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have an older Whirlpool washing machine (Stylemaster # 907675.) It leaves behind lint galore and white smudges that are almost impossible to clean off. Do you think it has a filter that might need...
WHIRLPOO STOP USING FILTER IT MAY BE COMING FROM THE TUB. TRY RUNFIN A WASER CLEANER LIKE C.L.R. CAUSIM LIME AND RUST REMOVER. AND TAKE THE SOFTER OUT BY PULING THE BLUE RIND UP AND PULL THE SOFERNER UP AND PUT IN WASHER TO GET CLEAN IN HOT WAER LOW CYCLE.
Jan 25, 2009 | Washing Machines
Washer Is Dribbling Water Into Tub
you have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
ICE MAKER AND WATER SUPPLY DOES NOT WORK
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Feb 18, 2008 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
103 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
