Question about Motorola Mobility RAZR V3
Problem with the number of rings
When I call my girlfriends phone, she has a 20 - 25 second ringtone, but she only hears 10 - 15 seconds of it then it says missed call. When I am calling it, I let it ring all the way till it goes to voice mail, which is about 4 rings. I play the same ringtone on my phone and when she calls, I hear the entire ringtone.
Any ideas?
  • 316 Answers
Remove the voicemail or extend ring time
don.t know is this code works world wide but you can try otherwise ask the provider to lengthen the ring time to 30 secs
then enter country code IE 61 for australia
* then vmail number IE 321 for optus
so your code should look something like this
then hit call.
remember the 61 and the 321 will vary on country and provider
Posted on Nov 09, 2007
2 Suggested Answers
SOURCE: Ringer
Try going to the fowarding or the voicemail, u will get to choose how long it rings or u can just turn it off which will automatically foward to voicemail, hope that helps
Posted on Aug 10, 2007
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
Aug 11, 2011 | Cell Phones
I can only get three ring tones on my Iphone, even though all of the ring tones show up under my device in Itunes. Please help. Turning off the phone and restarting or re-synching doesn't work.
Ringtones that exceed 0:30 (30 seconds) that are in your library will not sync with your device. If these ringtones that won't sync are over 30 seconds you will have to find new ones that are less then 30 seconds.
Mar 03, 2011 | BLACKOUT LABS Ringtone Designer Free
My Nokia 2600 rings for about 10 seconds and I miss calls because I cannot hear the ringtone, even though I have turned it up to the max. I am not deaf.
Hi, some ringtones are quieter than others so try another ringtone, and if you want it to ring longer go into the settings then call settings then choose call diverts and then turn them all off, then turn the one on that says when out of reach and not available this will then keep the phone ringing when its on but when its off it will go to answer phone.
if you dont need to use or never use the answer phone just turn all the diverts off then the phone will keep ringing for ages when someone calls you
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 30, 2010 | Cell Phones
Rings that come with phone are short
It sounds like it's not the fact that the ring tones are short, but that your device is set to go to voicemail in a short amount of time. Call your service provider and they can set the time to a max of 30 seconds before the call is sent to voicemail.
Apr 30, 2009 | LG Vu CU920 Cellular Phone
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
Can I set the ringtone to ring for longer?
Try typing the following into your phone, then hitting SEND - replace the words in brackets with the relevant numbers):
**61*(voicemail or diversion phone number)**(seconds delay before diverting)#
This works for "Divert on No Answer". To check the status of this diversion use *#61#
Jan 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My nokia n95 8gb doesnt display some incoming callers names?
Call ID must be activated in your phone. Your cell phone provider customer service must help you with that.
Jul 20, 2008 | Nokia N95 Cellular Phone
My ringtones
Check the volume level of the ringer in the settings.
Secondly use a loud tone. There are some in this package
Mar 31, 2008 | RIM BlackBerry Pearl 8100
There are two types to get you many ringtones- the first is by
bluetooth,need two phone and on the bluetooth both phones
send the ringtone first phone to second phone.
AND the second formula is-- by you will purchase from this site.
Feb 21, 2008 | Nokia 6300 Cellular Phone
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
249 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
