Question about Ruud Matching Split Air Conditioner
The inside is fine the outside fan does not spin yet spins freely with the screwdriver trick
  • 2,418 Answers
Most likely the condensor fan has gone bad. But it can be bad wiring, this fan should run any time the compressor is on. Pull your electricl cut off. (Turn off the electricity) open the control panel look for the area above where the hard pipes come into the mach. look for any burt / loose wiring. If the compressor comes on most os the time the fan motor is bad. When / if you replace the motor do get a new cap to go with it change them together.
Posted on Jul 03, 2009
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
My LG LWHD1200FR air conditioner turns on, but the fan doesn't spin and no cold air comes out. What's the problem? How do I fix this?
Which fan doesnt spin the inside fan or outside fan? If its the outside fan try replacing the dual capacitor for the fan and the compressor. First take the fan blade and see if it spins freely if you spin it and it stops immedietly the fan bearings are bad. If it spins freely replace dual capacitor. If trhis helps please rate me and do a testimonial.
May 31, 2011 | Heating & Cooling
Outside runs fine but inside squirrel cage motor fails
Go to the thermostat and place the fan switch in "on" and see if the fan runs. If it doesn't then check the circuit breakers. If the circuit breakers are on turn off the power and spin the fan by hand to see if it turns freely. If it does then check the fan capacitor. Let me know what you find.
Sep 26, 2010 | Weather King 10AJA3001AH Air Conditioner
The inside fan works but there is no cool air coming in. The outside unit makes a humming sound but fan doesn't spin
First turn off power to the outside unit and use a screwdriver or something that you can reach the fan blades with and make sure the fan rotates freely. If it doesn't you probably need a new fan. Next check the capacitor. If it looks swollen, it's bad. If it's not swollen then you will can use a multimeter with the capacitor test function and check it. You can also take it to a heating and air supply and they will test it. Some units use a double capacitor that runs the fan and the compressor so you will need to take note of where the wires connect to it.
Sep 17, 2010 | Goodman CLQ36AR49 Air Conditioner
Lennox central air for home not kicking on. Fan on the outside not spinning but motor is making a humming noise. No cold air coming in home. We have circuit breakers they are turn to the on position. ...
Is the indoor fan working? The problem with the outdoor fan sounds like it could be your capacitor. Turn off the power to the outdoor unit and make sure the fan turns freely using a screwdriver or something that will reach the blades. If it turns freely then it is probably the capacitor. Let me know what you find.
Aug 25, 2010 | Goodman CLT36AER36 Air Conditioner
My furnace fan indoors runs, but the outside condenser is silent. Fan spins freely. Any thoughts?
check the fuses or breaker. but what do mean buy fan spin freely is it running?
Jun 26, 2009 | Heating & Cooling
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
Outside A/C unit
you should be able to hear the compressor motor running. if you dont hear anything its more than likely ists a control problem. is the fan running inside?
Mar 15, 2009 | Ruud Handle Air Conditioner
Ruud Matching Split Air Conditioner Logo
227 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
