Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Water dispencer stpped
I hae just replaced an admirral water filter and now the water has stopped
  • 11,896 Answers
Filters are only made to go one direction. make sure the arrow (if there is one on your filter) points toward the output side where the water is coming out of.
Posted on Jul 02, 2009
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have water running to the fridge and contact at dispencer by I cannot get water to ice maker or dispencer
Look on the backside of the fridge for a small shutoff valve which may be turned off. Also, if your fridge has provisions for a filter, check for a clogged or missing filter. In either case, you will have to replace the filter.
Jun 11, 2010 | Frigidaire PLHS267ZA Side by Side...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Water dispencer
Hi. This is normal and there is nothing wrong with your refrigerator. Whenever you replace the water filter on any refrigerator, you must run a couple gallons of water thru the water dispenser until all the air from the new water filter is out. Use a large container to do this. The water will not stop when you pull a cup away because the water valves used on refrigerators are so weak it will not close until it has pressure on both sides of it. If you don't get the air out, the air from your new water filter can go to the ice maker and stop ice production. So flush the air out of your new water filter. The water you are drinking from your drink dispenser may not be healthy. It may contain a small plastic floating substance. This is part of the plastic that the water tank is made of. The chemicals in the water do this. You will have this problem even with a new water filter because the water tank is after the water filter. You have to replace the Water Tank. The water tank is located in the refrigerator section on the bottom back wall. I sell low cost new designed Water Tanks on Ebay as username: themackshack. Good Luck, Mack
Mar 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
87 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
