Question about HP DesignJet 750c InkJet Printer
ON MY HP750C EVERY PLOT WANTS TO SERVICE THE CARTRIDGE RATHER THAN PLOTTING CONTINUOUSLY so i have to sit by the plotter rather than plotting a batch.
    Scholar:
  • HP Expert
  • 123 Answers
You could have a print head that is on its way out but more likely you have a drop detector that needs to be cleaned out or replaced. The drop detector is part of the service station. If you are happy with the print quality, try turning off PEN CHECKING from the menu. The printer will stop using the drop detector if you do that and should run unattended batches. You run the risk of running out of ink and the printer not being able to see that, though.
Posted on Apr 16, 2010
    New Friend:
  • 20 Answers
Disable pen check option thru Front Panel Menu Button
it will not check the cartridges & not service the cartridge
Posted on Sep 15, 2009
  • neeraj1412
    neeraj1412 Sep 15, 2009
    disable pen check option thru Front Panel Menu Button
  • neeraj1412
Is there some way you are supposed to be setting up the calculator before you use it?
That would depend on what you want to do with it. If you want to graph a polar plot, for example, you'd set it for polar plotting. If you want to graph a parametric plot instead, you'd set it for parametric plotting.
Jan 16, 2014 | Texas Instruments TI-84 Plus Silver...
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
My plotter is recieving info. but takes forever to start plotting.
Try turning the nesting function off. This can save paper when you are doing high volume printing, particularly with smaller drawings but wil cause extreme delays if there isn't a steady flow of drawings going to the plotter.
Apr 14, 2009 | Computers & Internet
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 750c InkJet Printer Logo
219 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
