Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
  • 4,070 Answers
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line.
Posted on Jul 02, 2009
Have a GE side c side and can't get water thru the
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS25KGMAWW/0432/0165000/G0311087/00009?blt=06&prst=0&shdMod=GSS25KGMAWW
go here and look at part number 810,this is the water tank in the fridge section,get a hair dryer and heat up the tank where the water lines connect to it,also g.e. has problems with the water line in the freezer door the line freezes up.also when was the last time you changed the water filter?try this,open the freezer door and remove the bottom kickplate,on the left side you'll find a connector for the water line,disconnect it shut the door and hit the water dispenser,if water comes out of line where you disconnected it then you know the line in the door is frozen,if no water comes out i would change the filter and it that doesn't work i'd have to say you have a bad water valve.one more thing and this might sound crazy but if i didn't see it myself i wouldn't believe it,when you went to dispense water have you ever noticed that the condenser fan motor would sound like it was slowing down and also the strip in the middle where the doors close together touch it to see if it's hot,i've found three mother boards bad from this,i'd dispense water, and the fans would slow down, i hope i'm not confusing you by telling you this,lets stick with the basic things first disconnect the water line under the freezer door and behind the kickplate,shut the door and hit the dispenser,if water comes out of the hose the water line is frooze in the door,if no water comes out,heat up the water tank with a hair dryer,after a while like 5 to 10 minutes hit the dispenser but water will leak out the tube if the tanks frozen,if that doesn't do the trick i would change the water filter and if that doesn't work bad water valve,if you look down where the kickplate is you should find a tech sheet that will tell you how to jump out the ice maker,now what did you change out the ice maker?you said you changed two parts,what's happening that you changed the ice maker,was it not getting water to it,i mean if you're not getting water through the door and no water to ice maker,you either have a bad water valve or filter,start there and heat up the water tank,if that's frozen you won't get any wateralso look at this it will tell you how to start the harvest cycle on the ice maker,i beleive you shut it off for 20 seconds,turn it back on and move the arm in and out like three times.
http://appliantology.org/topic/29479-ge-icemaker-wont-fill-or-harvest/
hope this helps and good luck,let me know please what you find.
Jul 16, 2013 | Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi, I have an a GE Profile Model TPX24PPDCC fridge that came with the home I purchased in 2006. I believe the fridge is much older. I've been having problems with the water dispenser where water will...
Yes there is a way to disconnect the water line. Pull the Fridge out from the wall. The electrical power chord should be on the back side as well as the 1/4" water line. You need to locate a valve and shut off the supply water. Then you can disconnect the line with wrenches. It is located near the bottom.
Apr 01, 2017 | GE Refrigerators
Water does not come through to the icemaker or the water outlet. Is there a valve some place in side the ***? water is come to the *** but is it.
water comes to a valve1765e9d.jpgIt has a small line and a bigger line. The big line is for water in the door. The small lines goes up to ice maker.
Jul 11, 2010 | Refrigerators
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Water leak from ice dispenser line
hi..
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
399 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
