Sorry to say, but is sounds as if the TV has been heavily abused.
The menu burn can't be undone. All you can do is age the other parts of the screen to catch up. But that presumes that there's enough life left in the phosphor display to do that. It sounds like there isn't. Sorry, but from what you wrote I think this TV is past salvaging.
SOURCE: my vizio vp50 hdtv20a wont turn on i tried
It looks like your power board went bad.
Do you know the part # of the power board, email me at [email protected] and I can get it cheap for you.
SOURCE: my vizio vw32l hdtv20a no
Hi
Thanks for using FixYa. From what
you have described it seems the issue is with the power board or the main board
and we’ll need to check few things. When you open the unit up; take a look at
the power board-the board where the power cords/plugs goes into. You might see
some filter capacitors a little bulged up in the top-If this is the case-this
is your defective part(you can try to replace them-but some soldering equipment
is needed). If not, then probably the main board has gone bad. This is the other
board-where all the inputs are going into. All this is only recommended if you
have electrical expertise and know how to solder/re-solder components. Please
note that the TV components consists high voltages even when in off position. Please
do accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
SOURCE: My vizio vp50 hdtv20a has
Hi Check the connections on the back. If all is satisfactory. It may still be under warranty take it to be repaired.
