Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
NEED TO FORWARD A PORT AND CAN'T FIND MY ROUTER ON THE LIST. DOES ANYONE KNOW HOW I CAN OPEN A PORT FOR A 802.11g 2WIRE?
  • 4 Answers
Follow the steps here:
http://www.portforward.com/english/routers/port_forwarding/2wire/2701HG-B/Azureus.htm
Posted on Jul 04, 2009
How to open and close ports on your 2wire router for the x box 360
here's direct link on Port Forwarding
http://support.2wire.com/?page=view&article=21
there's a step by step walk through with screenshots..
hope this helps thanks roger
Aug 31, 2011 | 2wire (2701HG-B) Wireless Router
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
How do I port forward with my 2701HG-B router?
Use this link:
http://portforward.com/english/routers/port_forwarding/2wire/2700HG-E/2700HG-Eindex.htm
Then scroll down to the game you want to port-forward, click on that game. Follow all the instructions. Then do a Port checker test:
http://portforward.com/help/portcheck.htm
Now enjoy your game!
Oct 07, 2010 | 2wire 2700HG-B Router (2700HGB)
2wire 2701 block port 80
Go to the following link. This is just an example on how to forward ports for limewire. Use the same steps to forward port 80.
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/Limewire.htm
If it still doesnt work, try updading the firmware. In case this fails, then we have some issue with the router
regards
Sandeep
Oct 13, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 1800HG router keeps resetting
1) Check power cord. 2wire has known issues with power cords being defective. If you have a Multimeter, I would check to ensure the correct voltage and amperage and being delivered to the router first.
2) Need to resolve the "resetting problem" first. Then attack the port forwarding issue.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Port forwarding not working for me on the 2wire 2701HG-B...i follow the instructions exactly, but after setting up a firewall rule the port then gets stealthed instead of closed...how can i open it please?...
Here is the link directly from 2wire's website. Shows step by step on how to open the port.
http://support.2wire.com/index.php?page=view&article=21&text=port%20forwarding&cat=&sort=
If placed in DMZ plus mode, does the computer as you wished?
Feb 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Ip camera logon ptoblem
You might have forwarded the wrong ports of the camera to the wrong IP address. Make sure you assign static IP on the camera. Firewalls should be turned off as well.
Oct 26, 2008 | 2wire 1800HG Router (RG1800HG00)
Trying to use port forwarding
hi!
i tried to remote access your modem using the serial nos. but it didn't give me anything, pls try to run system setup wizard from your computer by accessing gateway.2wire.net or homeportal/setup, once you have configured the modem with your own settings, please let me know and i'll try to open some ports for you
Mar 23, 2008 | 2wire HomePortal 1100 Router...
Q-See System Not Listed in available computers
http://www.portforward.com/qsee/
Choose the model of your Q-See DVR and then select the model of your router.
Nov 11, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
99 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
