Question about Philips 37MF231D 37 in. LCD Television
The tv randomly will display the menu. You can't get it to go off, unless you turn off the tv. The appearance of the menu display has come quicker over the past few months. We tried the download,this worked for awhile,then problem came back. A local service shop said that it needed a skeeter board replaced? Cost of repair was around 400.00. Since then my friend has given the tv to me to look at. i used to work on tvs. I'm jyust trying to help him out and maybe fix the tv cheaply by replaceing the eprom, or the microprocessor board, if available. I currently have no schematic but can download one. I've had the tv playing for a total of 10 hours over the past 3 days. Tv has been working fine. Any ideas and part numbers,and best place to get parts? Thanks Jerry! Stonecat316@aol.com
  • stonecat316 Jul 06, 2009
    I appreciate your solution to my issue. Have you fixed this model of tv with this randomly appearing menu, or is the capacitor replacement just a fix for the known power supply problems of not turning on? The tv comes on fine for now,it's just that the menu will pop up and stay on according to my friend. I've not seen it do it yet. Your solution seems to sound like you actually fix tv's on a regular basis. I've had other general solutions posted, but none like this. Thanks Jerry!
  • 67 Answers
Um you might just need a fresh bulb inside the tv just so the tv doesnt do that so that should work they only cost around 100 to 200 dollers
Posted on Jul 07, 2009
    Sergeant:
  • 173 Answers
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Jul 06, 2009
    President:
  • 942 Answers
Hi...
have you ever try to reset this unit,
To reset your TV unit you just unplug the cord from the wall socket for five hours, the purpose for this is to drain the stored current in the memory IC, in order to erase the stored command. Then after five hours plug it again. To see what ever
Good luck !!!
Regards
PCmania
Posted on Jul 05, 2009
    Brigadier General:
  • 8,619 Answers
Hi Jerry
If its a Philips TV then the best place to get parts will be to contact philips, also you can try ebay. Please tell me the brand and model no so that I can assist you further.
Thanks
Rylee
Posted on Jul 03, 2009
  • 10,594 Answers
Your question shows Philips 37MF231D LCD TV model number.
You can download repair manual from Manual Zone for small fee and parts can be purchased from Shop Jimmy and Part Store.
Thanks.
Posted on Jul 02, 2009
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
Samsung TV HPS4253 menu continues to pop up randomly
Its probably the buttons (hopefully) you can open the tv and disconnect this control panel most of the time. Sometimes the remote (IR) signals go through this board. If the problem continues without board connected, its likely the main board = more expensive (100-300 $ part)
Feb 05, 2009 | Samsung HP-S4253 Television
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Black menu-like box randomly appears, covering the picture
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Sep 05, 2008 | Toshiba 15DLV76 Television
Turns on and off by itself unless I'm using the menu
This is just a suggestion because I had a similar problem with a Zenith TV many years ago. It was something in the tuner/remote sensor circuit that made the TV randomly turn on or off. You may have to have it repaired by a technician, but here is something to try: Put tape over the remote sensor eye on the front of the TV. This is to make sure some stray light is not turning off the TV.
Dec 28, 2007 | Mitsubishi VS-50803 50" Rear Projection...
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Black square in the middle of the picture
You have the set configured to display "text 1 or Text 2" in the closed captioning menu. You will need to turn closed captioning off to get rid of this box.
Jan 13, 2007 | Craig CTV-41904 19" TV
Philips 37MF231D 37 in. LCD Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
