Question about Olevia LT32HVE 32 in. LCD Television
My tv says "no channels listed" - Olevia LT32HVE 32 in. LCD Television
You need to go back to set up and do auto chanel select mine has done this
Posted on Oct 15, 2009
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
www.tomsguide.com/.../54774-4-show-program-information-channel-na...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' SourceForge.net
sourceforge.net > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have Warning message on DVD 'Your Guide Plus has not received TV Listings. Check your host channel.' What do I do?
Symptoms / Customer Description
TV Guide issues.
Example:
1. Not getting the correct info, or no information.
2. TV Guide giving double channels.
3. TV Guide grid comes up but no information.
[Primary Symptom Code: 118X ]
Solution
TV Guide information comes from the Host Station.
1. If no information on some channels or incorrect information not TV issue, but station not giving any information or incorrect information.
2. If grid comes up, but no TV Guide Info could be
siginal issue.
3. Double stations showing up. Unfortunately double listing is the way it's going to be. They have to send out all possible OTA listings for the area. You can hide the channels that you are not getting.
For these type of issues
Please have the customer call our Customer Support Line 800-222-7669
Our Call Center Rep. will fill out an investigation form with data pulled from the TV. These reports will be sent to Gem Star for their investigation, and the Call Center will get
back to the customer.
Apr 14, 2009 | Televison & Video
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Programming wrking fine, however i have no channel guide/listings
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Nov 26, 2008 | LG 42LB1DRA 42 in. LCD Television
No channels on list
You have to search for the channels. Go to your setup menu, and go to setup, then select TV, then do auto channel search. It may or may not have to be set on tuner to get to the TV options.
Jun 30, 2008 | Olevia LT32HVM 32 in. LCD Television
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Olevia LT32HVE 32 in. LCD Television Logo
91 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
