Question about Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Aire ccg2523 Natural Gas sealed cooktop. Ignitors on all 5 burners continue firing when I light RF burner. Ignitors will not shut off until I turn off RF burner. Also, how do you access parts on this sealed cooktop?
  • leevar Jul 02, 2009
    I'd like to get an idea of exactly what would cause this situation. Is it a part, a module, or a wiring problem?
    How does one go about finding this switch or replacing it. Part # ? This is a sealed cooktop.
    Brigadier General:
  • 8,619 Answers
Hi
It seems like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Also you can try to clean it. Please refer to the link and picture: Jenn-Aire ccg2523 Natural Gas sealed cooktop. - e11b706.gif Please do accept the solution and revert for further assistance. Thanks Rylee
Posted on Jul 03, 2009
  • 13,433 Answers
Parts for your cooktop are available at
http://www.partselect.com/MultiModels.aspx?ModelNum=ccg2523&searchTerm=&RefineSearch=0
have a look at the part diagrams, they may help you on taking it apart.
Posted on Jul 02, 2009
  • 749 Answers
Hi you need to replace the switch whic produces the spark.
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jmy gas stove wont stop clicking and all burners are turned off
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 26, 2011 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn Aire gas cooktop
sounds like your initor button is stuck. If you are able to remove it, take a look and see if you can adjust it. If not, it will have to be replaced. Good luck.
Jul 14, 2010 | Jenn-Air JGA8100AD Cooktop
Gas igniters on all five burners keep sparking (JennAir CCG556B)
Try cleaning around all the ignitors at each burner. Look for build up of cleansing product and/or food. Sometimes all it takes is a good cleaning and removal of a buildup to solve this. Worth trying before replacing a bunch of parts!
K
Jul 30, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Ignitors continue to ignite on other burners
the igniter switch are stuck /need clean contactor of the igniter .
Jan 08, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 36 in. CCG2523 Gas Cooktop Logo
522 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
