Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore gas: SMELLS
Our stove top AND oven smell almost like kerosene when using. We've thoroughly cleaned everything. What could be causing this? We are unable to currently use it due to this. THank you
  • Anonymous Dec 20, 2007
  • mshills277 Mar 17, 2009
    We have this same problem. The thing is, the landlord got us a brand new stove because he figured it was the old stove (we had also smelled a bit of gas when it was off). However, the new stove has not fixed the problem. We get a bit of this smell when we run the burners (blue flame with the occasional bit of orange), but a huge amount with the oven (When I was preheating it yesterday, the flames were orange, not blue). Any ideas what to do - I hate to call the landlord and tell him this did not fix the problem?
  • 1,314 Answers
Turn them on see if the flames are orange or blue then reply open the door and look from the side through the little slots in the bottom of the oven to see also is there soot and are you on natural gas or propane your reply will come to my e mail
Posted on Dec 29, 2007
I smell something burning when the oven is on...not as "eggy" as gas but I have a pregnant wife and I'm scared to use this thing.Is it just a new oven smell?
I would have a service call made and have the service technician check for correct installation
Smells ( that cannot be attributed to burnt food, gas ) should be investigated as they are the early warning signs of a problem
at least you will have peace of mind and may be advised as to a product that can be used to remove the smell
Sep 01, 2015 | Ovens
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
My oven wont ignite, it just smells like gas
I think you may need to clean out all the holes in the burner. That is usually the problem. Some food or juice drips may have clogged the holes and not enough gas is reaching the igniter.
I use a toothpik.
hope this helps
Jun 27, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
Can light the oven pilot light but it won't stay on when I turn the dial to oven temperature. I cleaned the oven prior to this problem with spray on oven cleaner.
I have a 2003 maytag performa stove and i turn the oven on but sometimes it takes a while to come on and smells like gas so and lately i cant get the flames going. i see that the pilot glows but still know flame coming from tubes.
Sep 27, 2010 | Ovens
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Chipped the porcelain or enamel off
yes they have almond , white, black repair paint used to get from walmart maybe not anymore i dont repair anymore but they do have it . it smells really bad an takes a long time to dry careful of over spray also getting on other parts of stove top
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Apr 06, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
451 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
