After loading updated hot sync program lost desktop display for palm one and data on hand held also had to change account name to load program
    Brigadier General:
  • 3,917 Answers
  • Did you perform the final HotSync operation? Sync again if necessary. Select your existing user name if asked.
  • Did you select the incorrect user name when you synchronized? Your data is tied to a specific user name. When you sync after the update is complete, you need to select the user name you had before the update. Here's how to change back to the correct user name and restore your data:
    1. Perform a hard reset. This wipes out the current (incorrect) user name and user data, but your smartphone will retain the update.
    2. Synchronize. Important: When asked for your user name, select the old user name you were using before you changed it. The backed up personal data and applications will be restored to your smartphone.
  • Programs that sync wirelessly only, such as Exchange ActiveSync and Express Mail, may appear to be missing data until a wireless sync occurs. Perform a manual wireless sync if necessary, then check your data.
Thanks for contactng Fixya.
Posted on Jul 02, 2009
What is procedure to delete courses from the hand held devise? i have the SG4 Model. Thanks
Hello.
GPS receiver units are designed to translate signalsreceived from a satellite into recognizable graphic information using mappingsoftware. These systems are dependent on the installed software, butlike all computers they can experience problems up to and including unexpecteddeletion of the software. Because of this, many GPS systems have providedsolutions to some of the most common problems.
Operating System Deletion
If the hand-held unit does not display any functionality when activated,first try restarting the system. If the unit is a hand-held GPS, try removingand then re-inserting the batteries to reset the system. If the system still displaysno operating system, contact a professional for service. GPS software can alsobe bundled or purchased as part of a more comprehensive device, such as aniPhone or other smart phone. In this instance, it is possible that the softwarewas deleted from the system during a sync with a computer. Try re-syncing thedevice with the computer and ensuring that the GPS application has beenselected to be loaded onto the unit. If this does not solve the problem, thesoftware may be corrupt. Delete the program from the computer and download itonce again to the hard drive. Then, re-sync the newly downloaded application toyour device.Update Deletion
Occasionally, an error in the download or an error insyncing with a GPS hand-held can cause updates such as operating systemadvances, bug fixes and new map information to be deleted or corrupted. If thisshould happen, re-download the update information and sync it with the GPSunit. If update information comes in the form of an SD or other data card, thecard itself may be corrupted. Contact Thanks.
Sep 21, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Nov 02, 2009 | Palm TX Handheld
Hot sync
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(2630)
With your Palm Zire 21 connected to your pc, go to the link above and run through the Palm HotSync troubleshooting dialog to see if any results come up that will solve your issue.
HotSync issues are unfortunately difficult to pinpoint and often will require a software update or patch to resolve issues.
Good luck with it!
OpenSource13
Apr 08, 2009 | Palm Zire 21 Handheld
Tungston E2
1. Upper left corner press time
2. Select delete
3. Pick program you loaded
4. press delete
Oct 07, 2008 | Palm Tungsten E2 Handheld
Hot sync
Try changing the HotSync settings
Select Desktop overwrites handheld for each conduit
May 30, 2008 | Palm Zire 21 Handheld
Error code 0x80040702
you should go into your computer to my computer. then file programs.look for palm then open. look for your user name open then look for backup file rename the back up file then hot sync the phone then use the same user name it will start up a new back up folder. you might have something on your phone that the phone do not agree with. this should work if you hot sync your phone to your computer.
Dec 23, 2007 | Palm Treo 650 Handheld
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
Nov 04, 2007 | Palm TX Handheld
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Computers & Internet Logo
David Payne
David Payne
