DVD Doesn't play. Sometimes the door opens and sometimes not
As above. VCR works perfectly.
  • 389 Answers
If you can give me the model number of that we can try resetting it.
Posted on Jul 02, 2009
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
Dvd read stuck canot open dvd canot eject dvd canot play dvd
if the disc was not installed in the plate fully and partly out in the front sometimes it gets stuck and u have to unscrew your dvd player andtake out the disc and it should work perfectly fine afterwards
Jul 14, 2012 | LG DVRK-898 MULTI SYSTEM REGION FREE DVD...
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Hi, I have a samsung dvd/vcr combo player model number v6800 which I hacked to be region free. It now plays dvds with region codes regardless from where they originate (ie; 1 or 4), however, some of my...
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
Jul 26, 2011 | Samsung DVD-V90K Multisystem DVD/VCR
DVD door will not open and dvd not play. Just less than 12 monthes old. Brought in NZ.
Hi there ,
If there is a disk stuck inside, then try the following:
Unplug power cord.
Plug back, and then press repeatedly the eject button while the unit is starting up.
Do this a couple of times.
If the above did not work, or there is no disk stuck inside, then wiring to unit motor, or mechanics may be broken.
In that case the unit must be taken apart, removing screws at the back and sometimes at the bottom to take out the upper cover.
Aug 04, 2009 | Samsung DVD-V6700 DVD Player/VCR
Dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Jan 20, 2008 | Philips Magnavox DVD/VCR Dual Player
Loss oF color
Bad chroma processor...accordianman
Nov 03, 2007 | LG V181 DVD Player/VCR
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
Jan 20, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
