Question about DEI GM Immobilizer Bypass
2001 Opel (vauxhall) Corsa key will not turn?
The steering wheel is locked to the right side. The spare key doesn´t work either.
  • alirezabadii Jul 03, 2009
    One day later the problem was fixed with 15ml of lock de-icer spray and some decisive attempts to turn the ignition key. My theory is that the steering wheel should not have been allowed to lock far to the right(or left).
    Touch wood! Glad to save a good amount of garage money.
  • wood44 May 11, 2010
    Have you tried moving the steering wheel back and forth while you try the key?
    New Friend:
  • 76 Answers
Take it to vauxhall they will charge u but the spair key can then be recoded and the staering wheel is locked to the right because the corsa alarms had a fault then ever the car was lifted from the rear the alarm cutout because it thought it was on a tow truck makeing them easy to steal just cut the hand brake cable and pull on to a tow truck!!!!!!! so vauxhall made the steering lock to the right so as then the car wouldnt go on to a tow truck straight.
Posted on Jul 24, 2009
    New Friend:
  • 166 Answers
Ur problem sounds like the ignition cylinder is broken they have a stem that suffers a lot trouble, take off the streering column covers and have the ignition cylinder exposed, u should be able to find the broken stem, if not it might be ur switch but its less likely to be the source of your problem
hope this helps
have fun
Posted on Sep 25, 2009
Where is speedo senser located on 1996 vauxhall corsa 1.4 auto
Hello Bill Seed,
It should be at the top... side of the transaxle
(only the top part showing)...
Prices do vary wildly so definitely shop around.
We have not imported Opel/Vauxhall here (usa) for decades
but the application looks very similar to the VW front wheel drives of the same vintage.
9114603N (I sincerely believe)
(don't know what this silly picture is about but the page displays what appears to be the correct part... (I think)).
9114603 Vauxhall Speedo Sensor
Expensive eBay picture (not the highest price I found).4
Speedometer Sensor for VAUXHALL Corsa 1 4 01 12 1996 Cambiare eBay
Jan 21, 2017 | Vauxhall Cars & Trucks
What is the oil capacity of an Opel Corsa 1.7 DTI utility manual gearbox and what grade oil should be used
As a standard, any front wheel drive car uses ATF lubricant or better known as Automatic Transmission Fluid to lubricate it's gearbox, you can recognise it by its colour witch is deep red, an opel/vauxhall corsa/astra 1.7d/1.7di/1.7dti/1.7cdti uses ATF II, not a easy trans to fill, suggest you let a dealer do this service
Jan 03, 2015 | Opel Cars & Trucks
I have Opel Corsa A 1989.Turning lights,emergensy lights and rear break do not work,I havent find broke fuse yet.Are they all in gabin left steering wheel?
not sure what your trying to say in that last line but sounds like a possible turn signal switch/hazard switch issue. A good wiring diagram will help
Dec 29, 2013 | Air Ride Management 1983-1993 Opel...
S reg vauxhall corsa 1998 central locking has stopped working
https://manuals.co/workshop/opel/corsa/opel-corsa-1997-2000-workshop-manual-haynes/5530701/3
You might have just blown the fuse, otherwise it could be the control module wiring has been damaged.
Check tthe wiring in the manual above.
Apr 23, 2017 | Cars & Trucks
Fuse box for vauxhall corsa 1.4 S reg
Opel/ Vauxhall Corsa D fuse box diagram and descroption
Version 1
http://www.autogenius.info/en/vauxhall-corsa-d-fuse-box/
Version 2
http://www.autogenius.info/en/vauxhall-corsa-d-2009-fuse-box/
Feb 12, 2012 | Opel Corsa Cars & Trucks
What is cylinder head torque settings on corsa 1.4 utility 2003
corsa? what in what country.
its no Isuzu, so im moving you to , Vauxhall.
(the list related)
Buick Sail
Chevrolet Classic
Chevrolet Corsa
Holden Barina
Opel Vita
Vauxhall Corsa
Opel Corsa. (bingo i think)
but what country?
we are usa, and dont have this car.
Nov 24, 2011 | Vauxhall Cars & Trucks
I can't start my car because my key won't turn, the steering wheel locked up
You have to wiggle the steering from side to side once it is locked. While wiggling it about try to turn the key at the same time.
Aug 02, 2010 | 2001 Saturn SL
CORSA B STEERING FAULT ( VAUXHAL/OPEl)
you could have a bent suspension arm or a tracking problem i would recomend you get these things checked first
if thats all fine i would go to your local brakers yard and get an electric power steering pump and fit it yourself
they are located on the steering column at the top and can be seen if you pull off the trim panel on the right
they are only held in by a couple of bolts
Sep 18, 2009 | 1987 Peugeot Liberte
Code- c1517. overheat protection mode not present
you might need to get your weels rebalenced that can sometimes cause the car to pull to one side than the other so go to a machanic to get the weels balanced
hope this helps
May 19, 2009 | 2001 Ford Focus
DEI GM Immobilizer Bypass Logo
796 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
