Question about Savin Office Equipment & Supplies
Savin 9925DP multifunction unit. Printer does not initialize. Is there a way to reboot to factory settings? Thanks
  • mlsptr Jul 03, 2009
    Thanks for the quick reply. Is there a way to access the Printer UT in a similar way? That is where the problem started from. If I can access the printer UT then hopefully I can correct the problem.
  • 313 Answers
IF YOU GO INTO THE SP MODE VIA CLEAR ALL THEN 107 AND HOLD THE STOP BUTTON TEH SCREEN SHOULD CHANGE GO INTO THE PRINTER SP AND YOU CN INITIALIZE FROM THERE // YOU WILL HAVE TO RE-ENTER YOUR IP AND NETWORK CONFIG AGAIN AFTER.. YOU CAN ALSO TRY TAKING THE NETWORK CARD OUT START COPIER WITHOUT AND THEN REINSTALL.. IF YOU TSKE THE SD CARD AND MEMORY OUT AND TRY A REBOOT THEN PUT THEM BACK IN THIS MIGHT ALSO HELP RESET YOU WILL GET ERRORS BUT YOU CAN RESET THESE AFTER.. GOOD LUCK IF YOU NEED MORE INFO LET ME KNOW
Posted on Jul 03, 2009
How do i reset a fusing unit counter on a CLP22
Hi. First of all did you have a code to tell you to replace the unit? I would like you to put the old unit back in and see if it lets you restart your printer. If it comes back up you have a problem with the new fuser you received. Take a few seconds to compare the unit and make sure all looks the same. If it's a remanufactured some times little things like tabs and the such get bent or broken. It should reset the counter when you set the new one was replaced. Hope this helped. I do get a little wordy at times
Feb 04, 2015 | Savin GENUINE RICOH FUSER UNIT (402451)...
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
Conflict with mac osx 10.6
must have the optional postscript installed in the unit and must have appletalk enabled in the user tools as well..
Nov 23, 2013 | Ricoh Aficio Sp 1200Sf Monochrome Laser...
Printer does not reset
HP tech support might help you in this matter you can reach them directly on this number (877-690-9305) or just follow the link Support For Hp Printer
Apr 18, 2013 | HP LaserJet 1200 Printer
How to clear back to factory setting
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Super NVRAM initialization
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
Codigosc542 savin 9925dp
first you go to SP mode and switch OFF and ON if still problem exists change the thermisters -thanks
Nov 29, 2010 | Savin Office Equipment & Supplies
I have hp 1522nf printer & it is showing memory low. It is continously showing error 49
Hello ! you can try doing the following:
1. Please ensure that the printer is directly connected to wall outlet.
2. Print a configuration page and check the firmware datecode. If possible update printer firmware and check if the issue occurs.
3. If the issue occurs, please perform a restore factory defaults. Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number.
a. On the product control panel, press Setup .
b. Use the arrow buttons to select Service, and then press OK.
c. Use the arrow buttons to select Restore defaults, and then press OK. The product automatically restarts.
4. If the issue still persists, perform a NVRAM initialization. An NVRAM initialization will return the following device settings to the factory-set defaults:
a. Turn off the product.
b. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
c. Wait until the message Permanent storage init. appears, and then release the buttons. When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Jul 02, 2010 | HP LaserJet M1522n MultiFunction Printer
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
don.farr@verizon.net
Oct 19, 2009 | Savin 9935DP Laser Printer
Can not connect my SAVIN 9925dp copier to a computer.
depends. these machines did not come standard with print option. do you have that option? if so does it have a parrell or nic? the nic is the new stanard connection, ethernet j45 connector. are you printing mac? if so you have to have the post script ooption in addtion to the nic and print card.
Sep 25, 2009 | Savin Office Equipment & Supplies
Savin Printer
There are initialization cards with printers. They look like credit cards or odd shaped key cards.
They need to be inserted into a slot reader on the machine to activate or reactivate them.
It should have come with the printer.
Feb 19, 2008 | Office Equipment & Supplies
415 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
