Question about Belkin Wireless-N Wireless Router with 4-Port Switch
Belkin N Wireless Router - wireless light no longer lit up
Router: Belkin n wireless router, F5D8233-4, version 1022uk
We've had the router installed for about a year now with no problems. Recently the connection kept disconnecting, up to two or three times an hour on bad days, though some days it would be fine. A few days ago the wireless light on the router went out completely but all the other lights are still on. Now you can get a limited connection to the router but this does not allow you to use the internet.
What could have caused the wireless light to go out and how can I fix it? Any help is greatly appreciated but I'm not great with computers so I really do need step by step help to fix it. Thank you.
  • streetboy1
    streetboy1 May 11, 2010
    Have you tried obviously restarting the router? Turning it off and leaving it for 10 mins then turning it back on again?
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Posted on Sep 30, 2009
I have a Belkin wireless router- I haven't used it in a while- I have a new laptop and it keeps asking for a security code. I've tried all the numbers on the router and even tried with the 00in...
if you had a cd that you installed it should be in the program.
Look for a Belkin program on your computer, the password should be there, you can change it after you've found it.
Sep 23, 2011 | Belkin N150 Enhanced Wireless Router...
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Hi. I have just set up a Belkin Share wireless router, Connecting to internet fine, but can't get printer to work via usb. Green light above socket doesn't come on when I plug it in. Thanks in advance -...
Ian, you have to 1st of all connect that printer to the computer and check if its working fine or not. Check if you have installed the necessary drivers and software that came along with the printer. Once that gets to go, then, connect the printer to Share router and check if the light above the USB is lit up to check if the port on router is working. If that is lit, you have to be connected to the router (make sure that you aren't connected wireless as a guest). Guest access doesn't have the rights to have file and printer sharing! Install the router monitor software properly that would be on the disk which came along with router or download the latest version of software from: http://en-us-support.belkin.com/app/answers/detail/a_id/3714/p/5132
You also have a brief tutorial on how to configure a printer with this router on the Belkin Support website. Here is the link for that. http://en-us-support.belkin.com/app/answers/detail/a_id/3796/p/5132.
For further clarifications, do revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 03, 2010 | Belkin Wireless Share Router (F7D3302)
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Jul 09, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless light on my belkin n- 150 router not
No Sync with the wireless, either may need to connect a wireless device or PC first... If now something to do with the wireless...
Mar 21, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My wireless light do not come on on the router at all.
The wireless light on the router lits up only when any wireless devices gets connected to this router. It is normal if this is the case.
But, if the wireless light is not lit even after any wireless devices gets connected, then in that case there are two possibilities:
a) LED behind the wireless light would have blown off.
For this, nothing can be done, though you may use the router till it gives you good wireless connectivity!
b) Reset the router (the reset button will be present at the rear end) and then re-configure with the CD.
Feb 01, 2010 | Belkin (F5D7230-4) Router (587009)
Router wireless light not on all other lights lit up. it will not connect with laptop
wireless light will only be lit up if a computer is connected to the router wirelessly. otherwise it'll be off.
Jan 24, 2010 | Belkin F5D8236-4 Router
Dell Inspiron 1501 cant find Belkin 2000
Do you mean wired or wireless?
If wireless, can you detect other wireless signal or ssid? If not, make sure your wireless is enabled. If yes, make sure the wireless light is lit on your router.
Jul 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
1,960 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
