Question about Samsung SGH-t629 Cellular Phone
None of the buttons on my keypad are working! I've tried taking out the battery and turning it back on. Not working. How do i fix this?
  • 43 Answers
Get in touch with the service center
Posted on Jul 02, 2009
My phone is not turning on properly.
while the phone is turned off,press and hold the +volume button,then press the on/off button for 10 seconds then release,you are now in "factory test".go through each test and reset if needed.
Dec 24, 2012 | Dual Dapeng A75 5" Android 4.0 Mtk6575...
When I press the keys on my MC9090 they give the wrong output.
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 11, 2012 | Zebra MC9090-G Barcode Scanner
I've been given a new company Samsung P530 laptop - but none of the function buttons work - I can't change the brightness or adjust the volume, turn on/off wi-fi etc etc. I've just tested all...
Try removing the battery wait for 10 mins insert the battery back into the notebook and boot it up again. If it still does not function properly then it is faulty and it will be under warranty.
Take it back to the supplier for a replacement or warranty repair. If you try to fix it yourself you most likelt void your warranty.
Sep 09, 2011 | Samsung R530 Notebook
My TI-83 Plus will turn on, but won't turn off. It also won't do any other function. I've tried taking out the batteries, taking only one out and holding clear well putting it back in. None of it seems to...
if you can connect the Calculator to the computer you can see whice application is installed sometimes one of the apps block the keypad
if the 2nd is not working its an electronic problem inside
i fix this calculators
ecrdn@yahoo.com
Sep 24, 2010 | Texas Instruments TI-83 Plus Calculator
The keypad do not work
Either a software re flash may help or a keypad replacement. Usually facial moisture could be a cause of this. i would recommend trying a blow dryer on the keypad for 40 seconds with out the battery to see if that fixes the problem
Apr 06, 2009 | Motorola Mobility W490 Cellular Phone
Hi. I own a Nokia 6300 and recently the keypad just stopped working. Its not all they keys, only 1, 2, 3 and the selection button. I've tried removing the keypad and seeing if it works then, but it dosent....
the problem is probably with the actual keys and not the battery. If the battery was the problem then it would effect the whole phone not just four buttons. Try opening it up and cleaning the buttons with an old brush and leaving it for a while. If that doesnt work then your nest course of action is to take it in to your local shop who will definitly be able to fix it.
Jan 27, 2009 | Lands Phones
My buttons on my cell phone...
Hi tina. Looks like the keypad of your phone is screwed. You will need to get a replacement keypad and it will be up and running again.Good luck!
May 23, 2008 | Motorola Mobility RAZR V3
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Some buttons on my keypad stopped working!
you need to take the phone and have the flexcable replaced on the phone.
Sep 20, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Dropped in Water Razr V3r
ok take the circular malfuntioning pice from the key pad take out blow dry and then take out the nuclear rector funtioning log and do same with that
Mar 02, 2007 | Motorola Mobility RAZR V3
Samsung SGH-t629 Cellular Phone Logo
60 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
