Question about Minolta EP4000/5000 CS/PRO Copier
Code C0400 contact rep at certain phone #...# out of service.
Making copies, and copier all of a sudden stops and gives error code C0400 (c is lighter than the #s). Copier is completely locked up.
Any assistance will be greatly appreciated.
Derek Lard
  • Minolta Master
  • 6,696 Answers
C0400 is exhaust fan code. Open the front door to clear. Make also all covers are closed front and both sides.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 12, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Minolta 3000 giving code c400
Posted on May 05, 2014
  • 31 Answers
Take the rear panel off the machine. In the back near the top you'll see a rat cage fan, below that you'll see a steel plate with a pancake motor below it. Take out the single screw holding that plate and remove the plate. Remove the ozone filter behind that plate and clean all the dust off of it, it'll probably be totally plugged, and reinsert it. That may or may not fix the problem, probably not because the fan motor is most likely going bad.
Posted on Jul 16, 2009
My Dialta Di2011 gives me an error code cof32 service call. What are the likely problems?
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
Feb 07, 2013 | Konica Minolta Office Equipment & Supplies
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
Error code E0000001-0002
That's a fuser temperature code that will need to be cleared in service mode. Press the additional functions key * then press 2
Mar 13, 2012 | Canon imageRUNNER 2200
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta EP1083 CS/PRO Copier
What is a code C0400?
Open the front door to your left upper, remove the access cover and press the trouble reset button the code you have is for the very bright light that comes on under the big glass when each copy is made. if the code comes back replace the exposure lamp and board. try web site below for a start,
Feb 04, 2012 | Minolta Office Equipment & Supplies
Error code 040
I think you will find this is error code c0400 this issue if the code i am giving you is correct is a fault with the exposure lamp you can test the lamp for cont using a digital meter if the lamp turns out to be ok there is a fault with the ae sensor board on pwb-h you would need to replace this board
Jan 22, 2011 | Minolta EP4000/5000 CS/PRO Copier
I was faxing a document and all of a sudden my copier stopped. The copy/quantity display is flashing L 6, what can I do to restart the copier. Thank you.
with the code showing press the start copy key and hold it this will give you the rest of the code most likely L6-10 laser unit service tech needed for that
Jan 12, 2010 | Sharp Office Equipment & Supplies
Samsung mobile phone error codes 3d010017
my mobile phone SGH-U708E will shut down without any reason suddenly while making a phone call, it will show the error code"3D010017" after restart it.
Aug 06, 2009 | Samsung SGH-t219 Cellular Phone
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
542 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
