Question about Microsoft Xbox Console
Weired floating yellow xbox in memory menu
When I go and select memory on my regualr xbox not 360 it shows the floating xbox thats usually green but its yellow is something wrong with it.
    Problem Solver:
  • 5 Answers
Nothing is wrong with it its just how it is mine used to do that and it worked fine
Posted on Jul 02, 2009
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 elite update wont work keeps signing me out
make sure that you have enough room on your memory device. also try clearing cache by selecting memory unit under system in the 360 menu.
Mar 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 power supply light turns yellow when xbox 360 is off (usually i think) and turns green when on, I've had one red ring on my xbox to,twice
make sure your xbox is in an open area where it can breathe, otherwise the one red ring means there is a hardware failure, if it is under warrenty send it back into xbox, otherwise there are some diy fixes on youtube
Mar 02, 2010 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Oblivion error
Does it not download correctly?
Make sure you delete the partially dl'd content (in the memory selection in the system menu). Also, clear the system cache by going to the memory menu. Select Y for device settings and then "clear cache."
In my experience, you have better luck downloading content OUT of the game you are downloading the DLC for. Go to marketplace, rather than go in the game and download.
Hope this helps,
Bill
Aug 26, 2009 | Take 2 Interactive Elder Scrolls IV:...
360 freezing
I've had a similar problem. It usually stems from the system overheating. Make sure your unit is getting enough airflow.
This page has a good run down of common Xbox problems and how to fix them yourself.
http://www.squidoo.com/Xbox_redlight_fix
Aug 22, 2008 | Microsoft Xbox 360 Console
No video output, just sound
well first make sure if you have a av cable that has both component and regualr avi jacks that the cable is set to right setting
HD - blue,red,green, and audio (red n white)
TV - yellow and audio (red n white)
should be a switch on the thick part the connects into the 360
Jun 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
