Question about KitchenAid Refrigerators
I'd like to see the water plasitic hose path to
Water not working. I'd like to see the water plasitic hose path to the server door.
  • 4,070 Answers
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Posted on Jul 02, 2009
Water leaks from handle and door
You will need to find out where the water is coming in from before you can fix the problem. Water will find the path of least resistance when flowing, you could start out by running a bead of clear silicon chaulk along the edge of the sill on the outside between the sill and concrete. If that does not stop the leak it may be coming in around the trim and running in behind the door jamb the running out inside. Once you chaulk and let it dry us a hose and wet it down real good and see if it leaks.
Jun 09, 2012 | Danby DDW1802W Built-in Dishwasher
GE Refrigerator Model GSH22SGRBSS NO WATER TO THE FRONT DOOR DISPENSER. ICE OK
Generally, the path to the water dispenser is as follows: water comes in from the wall, goes through a solenoid (valve), and through some tubing to a reservoir behind the fruit and vegetable compartments. From that reservoir, more tubing goes down under the refrigerator, then up near the bottom of the door hinge of the door that has the water dispenser.
First, listen for if there is a water running sound when you try to use the water dispenser. If there is not, then most likely there is no water coming from the supply at the wall, or the main solenoid where the water comes in is not working. If ice is being dispensed, you know that the switch that you press with your cup is good, but that doesn't mean that water is coming in to make new ice. It could be just existing ice being dispensed.
If you DO hear a water running sound, then something is leaking, possibly onto your floor. Follow the path of the water in the first paragraph to locate the leak. Could be that some tubing came off, or burst.
Nov 08, 2011 | GE Monogram Side by Side Refrigerator
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
The little vent above the words turbothermic plus is spitting out water during the cycle.
The fan assembly's drainage path is clogged. With time, food residue cloggs up the drainage path, inside the "Turbothermic" fan, and water accumulates during the drying cycle. The control panel, that houses the fan assembly, will need to be removed. Door panels will also need to come off. Unplug wires and drain hose to the fan, and loosen the round fan grill that secures the fan assembly (located inside the door). Take apart the fan assembly; unclogg drainage path and hose; and wash all parts. Re-assemble, install, and plug, the fan assembly, drain hose and door panels. Good Luck.
Oct 27, 2010 | Miele Premier-Plus Built-in Dishwasher
Hi, hoover hed6612-80 when the door is opened the
The problem is most likely that the drain is blocked. Remove the lower front panel on the dishwasher. You will see the drain hose connected to a small pump close to the floor. disconnect the hose and remove the pump. There will be some water so be prepared with some paper towels, or rags. Remove the small pump so you can visually inspect it on the inside, remove any debris you find. If there is no debris there go under the kitchen sink and disconnect the other end of the dishwasher hose. you can then remove the entire hose to inspect it for a blockage. If no blockage in the hose, you must then check the path of the drain water through the garbage disposal [if you have one] and then the trap.
Oct 01, 2009 | Dishwashers
It isnt cleaning ot rinsing properly
Make sure the drain hose has a clear path. Also where the hose connects to your sink drain,if you pull off the hose to check the connection for a blockage have a empty bucket handy to catch the water. If the drainage path is totally clear and it still does not work right then the water pump is weak. I hope this helps you.
Sep 06, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsungrs21dcns water dispenser problem
just below the doors of the frig is a kick plate. remove the kick plate. on the left youll see a water line that goes into the freezer door. there is a connection for that hose just under the freezer. disconect the hose the press the water dispenser. if water comes out of the hose then the water line is frozen inside the door. you can use a hair dryer to warm up the dispener area both from the front and from the back, inside the freezer, it will take about 30 min to defrost. but, if you get no water from that hose then you need a new water valve. more than likely its frozen in the door. thats common on ge models
Nov 26, 2007 | Whirlpool GS6NBEXR Side by Side...
No water
Try to blow thu the other end and see if you have something blocking it..should bo able to blow air thu if nothing blocking it... If you cant blow thu.. get some thin wire and try to find the blockage
Sep 01, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
94 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
