Bose SoundLink Wireless Music System 3189731100 Speaker System Logo
A
Anonymous Posted on Sep 04, 2014
Bose sound link not coming on when pressing on off button,it's fully charged
1 Related Answer
tonys_tiger
tony wahlman
  • 796 Answers
  • Posted on Jun 22, 2014
SOURCE: Why doesn't my Bose sound link charge?
bad battery
How to Connect the Bose Soundlink Mini to my Smartphone or Tablet?
  • Put the Soundlink Mini on charge. Then go to your Bluetooth device.
  • Go to the Bluetooth app. Turn on the Bose Soundlink Mini.
  • Press the Bluetooth button on the speaker. This makes it discoverable.
  • Watch the lights on the Soundlink Mini. ...
  • Press the 'Bose mini sou' button. ...
  • Listen to your music
  • Oct 18, 2016 • Cell Phones
    3answers
    How do I know if my bose mini soundlink bluetooth speaker needs a battery?
    [PDF]Owner's guide - Bose
    worldwide.bose.com/.../soundlink_mini/.../owg_en_sou...
    Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
    4helpful
    2answers
    I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
    Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
    2answers
    Problem with Airport express to BOSE Lifestyle
    When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
    anybody got a solution??
    Alex, Sthlm
    1helpful
    I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
    products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
    copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
    Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
    For manual copy and paste this link in your internet address bar under a new tab:
    2answers
    My fully charged 3g Iphone in the Bose Sounddock it keeps poppin
    Try putting your iPhone into "Airplaine" mode. It's possible that the radio frequencies from your phone are interfearing with the speakers in your sound dock.
    1helpful
    2helpful
    Lifestyle 12 by Bose
    No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
    Top Bose Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
