SOURCE: How I reset the maintenance kit on a Xerox Colour Cube 8870 please?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
The error code 99,013.00:49569 on a Xerox ColorQube 8570 printer typically indicates a problem with the printer's ink loader. Here are the steps you can take to fix the issue:
If the error code persists after resetting the ink loader, it may be necessary to replace the ink loader or the printer's maintenance kit. In that case, it's recommended to contact Xerox customer support or a qualified technician for further assistance.
