Reset the washer by unplugging the unit for at least 30 minutes. This will reset the Central Control Unit (CCU). If the problem reoccurs following a CCU reset, let me know. I hope this helps you.
Everything lights up and works on the washer, except the start button. I've run the diagnostic test and there are no errors. I've unplugged the machine, I've held the end of cycle button for 15 seconds. Nothing seems to work. I know the machine works because it runs through a complete diagnostic test. It washes, rinses, spins, but it won't work outside of doing the diagnostic test. Help!
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
Kevin
Kevin
Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset
Kevin
however, to resolve this control lock problem your whirlpool duet washer needs a reset. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
however, your whirlpool duet washer needs a reset to resolve the control lock
problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to
Kevin
