Question about Porter Cable 3,500 Watt 6.5 Hp Portable Generator #PH350IS
How do I test diodes on porter cable generator bsv 750 Thanx, samkjr@prodigy.net
    President:
  • 1,723 Answers
You have to have a multimeter and know how to use the ohms scale. Some meters actually have a diode test setting. Do you have a meter? I'd be glad to work you through it...
Posted on Jul 04, 2009
    President:
  • 497 Answers
You can test them with a VOC meter, just do a continuity test. if you read infinity, there no good.
Posted on Aug 09, 2009
I need a capacitor for a porter cable DBS1325 alternator but it is rusty and I cant read the labeling
Porter-Cable Portable Generator - Lawn and Garden Manuals
lawnandgarden.manualsonline.com > ... > Lawn and Garden Porter-Cable
Products 1 - 35 of 35 - Porter-Cable Portable Generator A02871-043-0. Porter-CableGenerator Instruction Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...Missing: dbs1325alternatorcapacitor
Sep 12, 2015 | Porter Cable Electrical Supplies
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
Porter cable 5500 watt generator - where are the diodes?
on back of stator in side gen, they look like silver round disks on the stator coil
Oct 09, 2013 | Electrical Supplies
DBSI325 will not put out voltage
Most of the problems like this are due to a failure of retention of the magnetic field to allow it to build up. Search Google for methods to "flash" the field. If you have had an accident of shorting or putting excessive load on the unit, rotating diodes of a brushless generator can be blown. Of the methods of flashing fields of the generators, I have had the most success with the method using TWO light bulbs in series between the utility mains and the generator. PLEASE be careful when doing this or handling electrical equipment where high voltage is present.
May 13, 2012 | Porter Cable PorterCable DBSI325 3250 Watt...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
No AC Output after sitting up for 2 years
If the field circuitry is good (winding, diodes, AVR, [rings and brushes if any], try to recharge the field for a few seconds when motor is running, with a 12 V battery "B+" to "F+", "B-" to "F-".
Jun 24, 2010 | Porter Cable 5,500 Watt Portable Generator...
Not generating power
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Nov 15, 2009 | Porter Cable 6,500 Watt Contractor...
Idle control inop
Check the small relays first, lightly tapping on them wile on may tell you the one that is bad but not all ways , if thats not it,Pull the circuit board and test or have a old tv repairman test the Diode's/resistor's on the board, if you find a bad one and do not know how to read the rating, take a digital close up picture of it and email it to one of many people selling diodes or resistor's on Ebay, buy it , solder it in.
Oct 22, 2008 | Porter Cable 10,000 Watt 20 Hp Portable...
Porter Cable 3,500 Watt 6.5 Hp Portable Generator #PH350IS Logo
226 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
