Inserted tape into the cassette and the door will not open so I can remove it and it will not play as inserted.
    Problem Solver:
  • 6 Answers
Use a paper clip to release it. there is a tiny hole located close to the deck, insert the pin and it shuold open. the tape might be tangled...
Posted on Jul 02, 2009
Where can I buy Pioneer CT-W701R Stereo Double Cassette Tape Deck Riemen Belt
If the methods listed in the manual won't open the door, then the tape is not inserted properly. Insert a golf tee in one of the two small holes below the tape door and slightly adjust the position of the tape up, down, or sideways. Then press the eject button and it should open. This will only work if the belt is OK.
Apr 26, 2012 | Pioneer Audio Players & Recorders
Jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Apr 28, 2009 | Car Audio & Video
Tape cover on unit is jammed
Don't force it, most likely the trouble is the capstan belt and U need to drive the mechanism foreword so the play mode can be released and the door will open but this will happen all the time till U get the belt replaced!
Dave, Electronic Doctors Email eledocs@hotmail.com
Apr 01, 2009 | Sony Audio Players & Recorders
Insuficient clearance for caset to install
There is a lock on the door mechanism. Unless the belts are good, the machine will not recycle to move the heads down far enough for the tape to be removed, so the door is interlocked to prevent damage.
Take the case off and push the door release and watch where the release lever hits a small nylon piece. You can pushit down with a pencil or screwdriver and the door will open. This white nylon piece will stay locked down if the blets are good and do not slip. They put the door latch in park allowing the tape to be inserted or removed.
Try to treat the belts with rejuvenator CaiKleen™ RBR Let them sit a while to get rejuvenated enough to not slip and the problem should be solved.
Sep 26, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
the switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Aug 18, 2006 | JVC HR-S9500 S-VHS VCR
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
Cassette loading process won't complete
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. If you're NOT still under warrantee you should at least open the VCR and Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY.
Dec 28, 2005 | Panasonic PV-V4021 S-VHS VCR
79 people viewed this question
 Grubhead
Grubhead
