Question about Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher
Maytag MDB5601AWB Does not start
Have had this dishwasher from new for a little over a year. Had no problems previously. When I close the door it appears to lock as normal. I push the button for the wash cycle (normal) and it lights up. But when I push "Start" nothing happens. The light does not come on, the machine doesn't start (no sound) and the "washing" light does not come on.
Not a power problem because the "normal" light is working. Also seems not to be a door lock problem. Have tried unplugging and letting rest and then replugging--didn't help.
Trying to determine if there is an easy (and cheap) fix before I call in the repairman.
Thanks
catriver
  • 878 Answers
SOURCE: Control buttons don't work, Help.
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. Catriver..post back.
Posted on Jan 08, 2007
jsrock516
  • 5911 Answers
SOURCE: maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Posted on Jul 31, 2007
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Keypad does not work
Time to buy a new one I guess.
Go check the fuse braker, it tripped probably.
Did you close the door properly , push it hard with a slam. It will start working. Jiggle the float inside the up and down.
Vitally
May 11, 2009 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher door problem
Your 10-year-old dishwasher may be suggesting it is time for replacement.
Mar 13, 2017 | Dishwashers
Latch on door won't close.
THe door wasn't closed right.  When I pushed the corner closed and it was lined up correctly, it latched.
Dec 05, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher MDB5600awb
i need your serial num its important 17
Sep 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Logo
268 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
