NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
Posted on Jul 02, 2009
Have a NX2 external driver. I'm trying to save some information from the laptop to the external driver and my computer is not recognizing the driver at all how can I fix that problem. I h
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
5173
Points
12
Switch usb on laptop. might b usb 2.0...
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Laptop no longer recognizes my iomega external hard drive
How old is your OS maybe driver needs for that device for that device is corrupt try to localize and reinstall driver for external HDD
2helpful
3answers
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
2helpful
My computer does not recognize my Maxtor OneTouch. also i Lost the Driver CD Maxator One touch II 300Gb Cache buffer 16mb Spin rate 7200RPM Combo Interface IEEE 1394 and SPB-2 Complaint (100to...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Not a problem, but question?? A Nexxtech NX2 was
Nexxtech NX2 is an external USB 2.0 hard drive which has a fast transfer speed. It posses no threat to you or your computer and all your privacy/passwords are safe.
2answers
How do i get my computer to use my external hard drive which i just installed
Which Operating system are you currently using? By default XP/Vista/7 should have generic drivers sufficient for using the device as external storage, To Check and make sure the drive is being properly recognized simply double click on the "My Computer" icon on your desktop if using windows XP. Or in Vista/Windows 7, click on the Start Button and then scroll over to Computer and Click. the hard drive should be listed in there. Take note of the drive letter . If you'd like to save items to it simply save to the new drive ( when within the program of your choice, Word, Windows Media Player etc ) by selecting the new drive in the "Save To" Window. ( Be Default most windows systems should store all information on the C:\ Drive ) your new external drive should be listed with a different letter ( F:\ G:\ etc )
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
2answers
Phillips external hard drive
There is a chance that the hard drive itself is at fault and the computer cannot recognize it try using it as a slave drive in computer. and use a recovery cd from boot to check it out
You could use thee ultimate boot cd (download) to check it
3helpful
7answers
Top NexxTech Computers & Internet Experts
john h
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
