Question about Toshiba Satellite A205-S5831 Notebook
My Toshiba laptop had its power cord yanked out by a dog. it was charging if the cord was held at an angle, now it wont charge at all. how can I get into the case to effect a repair, Im sure its just a prong bent inside the socket.
  • 61 Answers
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
My tablet wont charge or turn on.. I have replaced the power cord cause a friends dog chewed up mine.. it work just fine till I replaced the power cord
Hi. Can you post your tablet's model part no.? It looks something like this near where you'll find the serial no. --> PDA01U-00101F
Apr 12, 2015 | Toshiba AT100-100 TABLET THRIVE
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
My Computer Wont Charge!!
if the charger power up your laptop,that means that the charger is working fine,what you need to do is just replaced the battery
Jun 28, 2010 | Lenovo IdeaPad Y510 Notebook
My dog chewed my power cord. Dh "spliced" and taped for now. The laptop will work with power cord, but battery will not hold ANY sort of charge. Is the problem my cord or the battery now?
ask the dog.....!!!
ok sorry jokes apart...
was the battery working before ur dog helped u out...
remove the power cord and check how long ur battery can hold on till it dies down...when ur notbook is ON
if it holds for more than 10 mins then the battery will charge if the power cord gives it enough power to charge, else u may have a power adaptor that gives enough for notebook to work but not enough for the battery to charge at the same time....
u may have to change both the adaptor and battery....or else change the dog...ha ha ha...
u r the best judge....ask the dog to do some work on it may be......
just kidding....
Dec 14, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1501has no power connection
Sounds like the PSU connection has been broken from the motherboard.
Your laptop will be required to be taken in for service
Sep 27, 2009 | Dell Computers & Internet
Toshiba A205 won't charge unless I physically hold cord in
The most likely problem is the power socket on the laptop, it may be just a dry solder joint and needs to be resoldered or it may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars. If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 12, 2009 | Computers & Internet
TOSHIBA satelite wont turn on
If you have tried a new power supply and taking out the battery and it still won't start, then the problem is with the power management system on the motherboard. This means that the motherboard will have to be replaced. Check into your warranty, being that it's only 10 months old, it should still be under warranty. If so, then get it to them to be fixed asap, before they decide your warranty doesn't cover it.
Jun 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A205-S5831 Notebook Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
