Loss of power
Clean air filter or replace--new spark plug
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
SOURCE: i have a string craftsman weed wacker an the
Turn the big knob on the bottom LEFT to loosen it in order to access the drum with the line on it.
SOURCE: my 29cc 4 cycle craftsman
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
SOURCE: weed wacker started and wacked some weeds then the
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
SOURCE: 358.791070 filters for Craftsman weed wacker
not enough info! The fuel filter is in the fuel tank and the air filter is located out side the carburetor!
